500hp combo?
Old Jan 3, 2007 | 02:08 AM
SLP/Drew's Avatar
Default 500hp combo?
hey guys im lookin for a great head and cam package that yeilds around 500 rwhp...ive found some great heavy hitters that get around 450 with proper bolt ons
Old Jan 3, 2007 | 02:10 AM
PREDATOR-Z's Avatar
Very few around, but it can be done.
1st, list your car and mods.
Old Jan 3, 2007 | 02:19 AM
SLP/Drew's Avatar
LT headers no cats qtp cutouts, ls6 intake manifold, underdrive pulley, ported TB, lid, 12bolt moser 4.10
my next question would be if I could make a pretty streetable headcam package with spray to yeild over 500hp...I know you cant put too much compression cause then you cant spray.
M6 2002 LS1
Old Jan 3, 2007 | 08:13 AM
Specialized's Avatar
Just get yourself a mild cam/nice AFR small bore heads and spray a 100 or 150 shot on top of all of that. You will have no problem reaching your 500hp goal.
Old Jan 3, 2007 | 08:27 AM
PREDATOR-Z's Avatar
M6 2002 LS1
N2O loves compression, the more the better. You could make a nice 430>450 rwhp setup, the shoot another 100 and you have 550
Old Jan 3, 2007 | 09:22 AM
JRracing's Avatar
Buddy I'm on the same quest. I would have to agree with the post above.
Old Jan 3, 2007 | 09:56 AM
PREDATOR-Z's Avatar
I'm at ~11.88:1 SCR and 8.68 DCR, that motor begs for juice. (Nice way to clean up the pistons too )
Old Jan 3, 2007 | 10:00 AM
dame's Avatar
SOOOOOOOOOOOO SO true says one nitrous junky to another
Old Jan 4, 2007 | 03:22 AM
SLP/Drew's Avatar
when chooseing an after market head and cam package with the intent of useing 150 shot of nos, should I go with a 112 lsa or 114?
I want lope over the smoother sound but some shop guy said to run 114 lsa on a cam when useing spray
Old Jan 4, 2007 | 03:46 AM
LSGunZ28's Avatar
edit : ................
Old Jan 4, 2007 | 04:02 AM
SLP/Drew's Avatar
dude make your own thread dont jack mine
Old Jan 4, 2007 | 07:01 AM
nexvctm2001ss's Avatar
Old Jan 4, 2007 | 08:51 AM
Rede's Avatar
January 2007 issue of GM High Tech Performance features "129hp! Budget LS1 HEads/Cam" on page 28.
"Texas Speed's Magic Stick 4 Cam and PRC heads pump an LS1 up by 129hp!"
With the cam only, they hit 482.3hp and 439.1# torque @ 5100rpm.
Serious power from just a cam and a tune.
As far as I've seen, that the largest gain from a cam only application.
Old Jan 4, 2007 | 09:18 AM
cws T/A's Avatar
That was with an underdrive pulley only attached .
Spinning a/c , powersteering , mechanical waterpump , alternator those numbers will drop . Seems through a stocklongblock LS1 MS4 cam only gets around 415rwhp .
Top notch cylinder heads , induction , and lots of compression .. 500rwhp is possible with an LS1. Its already been done and recently . Looks like the owner drives it on the street . Search: Trick Flow
Old Jan 4, 2007 | 10:02 AM
cws T/A's Avatar
http://www.youtube.com/watch?v=GlU4i...elated&search=
Old Jan 4, 2007 | 10:16 AM
slow94GT's Avatar
bolt-ons and a 150 shot. :x
Old Jan 4, 2007 | 03:01 PM
LSGunZ28's Avatar
sorry
