ported my heads what do you think
200 - 134 & 116
300 - 197 & 144
400 - 250 & 189
500 - 290 & 219
600 - 315 & 235
650 - 320 & 240
congrats though cause those look like some kick *** #s. did you get a valve job? stock valves?
200 - 134 & 116
300 - 197 & 144
400 - 250 & 189
500 - 290 & 219
600 - 315 & 235
650 - 320 & 240
I have a set of hand ported 243's with stock valves and 229cc intake runners that just flow 300 cfm and .600. with good low and mid lift flow also.And my heads were ported by someone with lots of experience.its tough to say if those are any good or not with the little information given
install the valve into the port, and seal that with grease on the stem and install rocker arm bolt to seal that.
who knows what the +/- range should be if someone were to actually measure all the ports?
