do i need to replace my cam or will li be ok
What exactly happened to the lifter? You might wanna investigate that so it doesnt happen again.
To sum up, If you try and reuse a bad cam, expect to have to pull the heads again. You might make it 1000 miles, you might make it 15K, but chances are whatever killed your first lifter will kill again, and so will the pitting.
