FIPK Dyno results
When I pull my lid off w/ftra and look at the filter you see a small strip of the part of the filter you actually use - everybody flips their filter around and uses the other half before they clean it. It is not much surface area. Look at the size of that filter on the FIPK!!!
I don't want to use some 2" duct - NO, pull out the bumper support and get rid of the wiper fluid resevoir and run some 5" ducting straight to the FIPK filter. It won't be "ram-air" but will definitely help.
Do it Trevor and then back it up at the track - and definitely cut out as much of that "pretty" plate that K&N gives you to allow as much air as possible.
Eric
Eric - It's good to hear from you! What are you up to these days, and are you still driving the 'vert?
[ March 02, 2002: Message edited by: Trevor D ]</p>
Back to the dyno dude! <img src="gr_grin.gif" border="0">
Tony
<strong>I also think these should be dyno-tested with the hood shut. I know that the hoods come down and probably rest on top of that filter, possibly blocking alot of filter area. I wonder how effective this setup would be with the hood shut vs a lid setup.
Tony</strong><hr></blockquote>
Well it would be accurate to dyno with the hood shut since its that way when you drive BUT when you drive there is also air being pushed into the filer area.. the only way a closed hood test would be valid would be if you had a big a$& fan blowing <img src="gr_stretch.gif" border="0">
If you REALLY feel you need to do the FRA on this then cut the hole in the right place.. it wont matter if its a little behind the filter so long as it move outside air into the general area of the filter..
Tony, the filter actually has a few inches between the top of the filter and the hood.. plenty of room for air to circulate <img src="gr_stretch.gif" border="0">
1 will i get water in my motor
2 which lid seals the best
3 will my car run hot with the ftra
4 i get alot of trash in my air box with the ftra
5 i have to clean my filter all the time
my main reason for switching is reliability i wasnt happy with the fit of the lid i didnt like the idea of my wife being in the car and hitting a puddle i really didnt like seeing sand in my air box i plan on having this car awhile to me its a better system who cares if im .1 slower at the track
