Pulled motor???
Old Jan 7, 2007 | 10:02 AM
TN94Z's Avatar
Default Pulled motor???
Well, I pulled the motor yesterday to fix a few leaks and was wondering if there was anything I should think about doing while it is out? I think I am going to get some ARP rod bolts. Is there anything else?
Old Jan 7, 2007 | 11:03 AM
slow trap's Avatar
ls6 pump ?
Old Jan 7, 2007 | 11:05 AM
brad8266's Avatar
rod bearings cant hurt.
Old Jan 7, 2007 | 11:12 AM
cowboysfan's Avatar
polyurathane motor mounts.
headers, it will be easier to install then motor first.
fuerzaws6
Old Jan 7, 2007 | 11:20 AM
TN94Z's Avatar
It already has a Thunder Racing oil pump and I have a set of poly motor mounts in the floor right now. I am definately doing the rod bolts. Thanks for the suggestions. Anything else?
brad8266's Avatar
fuerzaws6
yeah poly mounts fo shizzle while the engine is out. He has all the boltons already.
Old Jan 7, 2007 | 11:28 AM
cowboysfan's Avatar
well then cam, underdrive pully, maybe windage try will oil pan is out. hell stuff a ls7 while ur there.
fuerzaws6
Old Jan 7, 2007 | 11:35 AM
TN94Z's Avatar
Yeah I have thought about that!! I already have all bolt ons, TRex cam, UP, etc...I guess it is pretty much what it is now. I may try and find me a set of heads..not sure yet. Anyway, thanks guys
Old Jan 7, 2007 | 07:40 PM
Cop Car's Avatar
katech rod bolts, oil pump, LS2 timing chain..
if you are even thinking about doing heads, do it now while its out.
Old Jan 7, 2007 | 11:24 PM
TN94Z's Avatar
What about an aftermarket flywheel? Any advantage to that? Haven't thought about the timing chain. Is that just a straight up bolt on install?
Old Jan 8, 2007 | 12:57 PM
Cop Car's Avatar
timing chain is so easy, and its less than 50 bucks
TCI flexplate might be a good investment, i did it when i re did everything on mine
