Cammin' the Z06
No... wasn't planning on porting the TB.
However, my block is not drilled/tapped for the timing chain damper so that's goin back. Apparently '04 LS6 blocks and LS2 blocks are, but not mine
Oh well that's $90 back in my pocket.I'll probably get the guages back in the car tonight, but the real work begins tomorrow. Tonight's the GF's best friend's b-day so I'm along for the ride.
Oh well that's $90 back in my pocket.I'll be doing a cam myself in a few weeks, so I hope mine is drilled already.
Thanks for the update!
TEA trick flows are the way to go ALL the way!
BTW, trust me, hinges on is easier. There are studs on the frame, couldn't be simpler. Once you snug the nuts, you can shift the hinges until they match your outline. The other method requires you to have the hood half-open to insert the fasteners, PITA.
LS2 chain on the left, it's beefier.
Stock oil pump removed.
Installed cam gear, must allign dot to dot for proper cam/crank orientation.
Cam gear bolted up, timing chain in.
Place new o-ring on oil pickup tube.
LS4 high volume pump in.
Drilled crank to pin it... pulley can never back off. Normally this is done in supercharger applications. I didnt take a picture of the drilling fixture used.
Cleaned timing cover, replaced front main seal, new gasket.
ATI super damper (10% underdrive) compare to stock damper. This one's special, used on most all NASCAR motors should eliminate all crank harmonics.
Crank pulley install tool from LS1tech, nice piece.
Pulley on.
1. Do you know the under head length of the oil pump mounting bolts?
2. How do you install the pin in the balancer and crank?
Thanks!
Since the ATI pulley has a keyway machined into it you pin from the top side of the crank (as seen in the pic) vs. the front like many do w/ other pulleys.
First, you install the drilling fixutre and run in an old bolt and get it wrench tight. Then using a 8" 11/64ths bit and a good drill you drill until you hit the bolt, make sure the motor is fairly well sealed from shavings (I used rags and paper towels and painters tape). Then remove the fixture, set the drill to low speed, and ream it w/ the 3/16ths reamer that comes w/ the pinning kit. Then take the ATI supplied pin, dab some grease on it, and stick it in the hole. Then as you set your pulley on the crank snout make sure the keyway is lined up w/ the pin.... then proceed w/ pulley install.
