Need info on pulling the ls1 out of the car!
THanks
[ March 03, 2002: Message edited by: zombiedude ]</p>
http://www.xs-fx.com/raughammer/remo...tmotorpics.htm
Josh S.
only a couple pics here:
https://ls1tech.com/ubb/cgi-bin/ulti...&f=20&t=000279
We've got about 80 more on another guy's camera
Had the cooling system and AC outta the car already.
Rolled the car in, up in the air to finish the disconnect on the under side. Back on the ground, to pull the last bit of wiring disconnect. Unbolted the trans crossmember and cradle. Disconnect front brake lines. Lift car off body.
Then pull the motor off the cradle, and put the cradle back in to roll the car back on the trailer.
4 hours time for pull and reinstall of front suspension.
Josh S.
-drain coolant
-shifter handle (6speed only)
-lid/maf assembly
-y-pipe
-undo torque arm from tranny
-driveshaft
-undo hydraulic clutch line going to tranny (6speed only)
-PCM and necessary connections on passenger side and connection under passenger side dash board
-AIR tubes from headers
-steering shaft
-fuel line and connection to EVAP on the intake manifold
-undo vacuum line going to brake booster
-front sway bar
-remove AC compressor and tie wrap out of the way (no need to discharge AC)
-alternator wire
-starter
-undo plug going into the oil level sensor on passenger side of the oil pan
-undo passenger side front 02 sensor
-grounds on side of block (driver/passenger side)
-cruise control cover shield
-all coolant hoses
-undo front suspension (shock bolts, etc.)
-front tires
-remove 3 bolts/side holding k-member to car
-remove 4 bolts holding tranny cross member to car
There is a few other things I know I'm forgetting, but you get the general idea of what needs to come out. It's not hard at all.
Jason
[ March 03, 2002: Message edited by: Jason99T/A ]</p>
i removed mine before pulling the motor out and would like to install them while the motor is out if possible.
Raughammer's page has given me what i needed to know...but i would rather not pull the tranny if possible!
Thanks
