Build my Engine
Old Jan 10, 2007 | 12:02 PM
dreamls1's Avatar
Default Build my Engine
I am building a 346 with twin turbos. It is going to have forged internals and be able to handle 700-1000HP. This is going to be a weekend car with mostly street use. Please help me picking out my internals, Pistons, rods, etc. I am starting on it asap. Please be detailed and let me know where i can buy them. thanks!
Old Jan 10, 2007 | 12:48 PM
HAMRHEAD's Avatar
Iron block, stock crank, callies billet rods, diamond pistons, ARP, main studs, billet main caps. Shoot Tom at Speed inc an email and let him know what your plans are. You will also be at 370ci when done too. He helped me with mine.
Jason
Old Jan 10, 2007 | 01:59 PM
dreamls1's Avatar
OK i will sent him a email. I was wondering the specs of the internals not the brands.
Old Jan 11, 2007 | 07:14 AM
dreamls1's Avatar
Anyone Else? Ideas?
Old Jan 11, 2007 | 07:58 AM
kawasakiklx's Avatar
run twin turbo on the stock longblock and let us know how it goes (or doesn't go...)
Old Jan 11, 2007 | 11:11 AM
dreamls1's Avatar
HAHA, I think im going with a Sportsman 348 from speed inc, and then a gridle.
Old Jan 11, 2007 | 11:12 AM
Gauge's Avatar
11Second Club
I basically built what HAMRHEAD described except that I have Mahle pistons and a stock block. I kept the stock crank, got Compstar rods, Mahle pistons, ARP main studs, Clevite bearings, Melling oil pump... should be good for around 700-800HP, I think. The iron block would help improve that.
Old Jan 11, 2007 | 07:40 PM
the.erinyes's Avatar
With the girdle, you do not need an iron block. The girdle will support upwards of 1,000 - 1,200 HP. I am putting one in my build, although I will only be at 500 HP NA.
Good Luck!
Old Jan 12, 2007 | 07:27 AM
dreamls1's Avatar
Thanks, ya i am going to do the 348 alum, with the gridle. I have heard good things.
Old Jan 12, 2007 | 09:26 AM
dreamls1's Avatar
What turbo are good for 348 that support 1000hp and spool fast? Twin 66 or 67?
Old Jan 12, 2007 | 02:17 PM
Chewy72SS's Avatar
Twin T66s would work, twin T61s or Gt35Rs are also good turbos for that displacement. How much boost do plan on running?? The A/R is what will determine how fast they spool. A high A/R like .96 on the turbine housing will spool quicker than a smaller one like .68. Also, ball bearing turbos spool a couple hundred RPMs quicker.
Old Jan 12, 2007 | 02:31 PM
dreamls1's Avatar
not sure how many psi 21psi maybe? The 66s sound good. Whats a good brand and a cheap place to buy them.
Old Jan 12, 2007 | 02:39 PM
Chewy72SS's Avatar
Hmm...running that much boost, I would consider running a stock bore iron block for more cylinder wall strength to minimize distortion. As for the turbos, check out some of the LS1Tech sponsor sites. ForcedInductions.com has some good prices as do many others. You don't want to cheap out on the turbos, and whatever you do...DON'T eBAY IT!!
Turbonetics and Garrett turbos are probly top of the line...but pricey.
Old Jan 12, 2007 | 03:07 PM
dreamls1's Avatar
Well i dont know how much PSI, however much it take me to get around 850+rwhp.
Old Jan 12, 2007 | 07:15 PM
Chewy72SS's Avatar
You could hit 900rwhp with under 20psi if your motor is built/tuned right. I've seen 1,000+hp at the crank with Twin T61s running 18psi on a 346ci aluminum LS1, with the stock crank...just to give you an idea. Although, I'd upgrade the crank for security reasons.
Basically, it's all about putting the right parts with the right parts.
I think you would be good with twin T66 turbos. I would recommend running under 20psi to keep clear of detonation, unless of course you drop the compression down with a dished piston to mid 8:1. I find it best to keep the compression higher and run less boost. This way, when you are on the street running low RPMs you will still have decent power and won't have to rely on your turbos for all the power.
Run a forged bottom end (crank,rods,and pistons), decent cam (Speed Inc.'s TU1 turbo cam= 225/225 .581.581 113LSA -1degree overlap is a good one), LS6 intake (at least), some good flowing heads (317 6.0l to bring the Comp. down unless you plan to run a deep dish piston),and of course...a good tune.
These are just some guidlines to get you started. Spend some time on the web searching through the forums here, there is TONS of great info on engine combos that work and ones that don't.
Old Jan 14, 2007 | 12:59 PM
dreamls1's Avatar
thanks for your help
