Where is the proof that big cams are better?
Where is the proof that the big cams put down the power? I'm not talking about a dyno number. I'm talking about an impressive E.T. at the track!
I am well aware that cams are not the end-all indicator of E.T., but somewhere there must a BIG cammed car laying the smack down. If so where is it at? I would consider anything at 229 duration or larger to be a BIG cam.
For example the 232/232 GTP cam.....why so freaking big? Where are the track times to support using such a big assed cam. What about the ARE 226/234? Or the ARE 240/240? MMS 229/229?
So where is the beef? Does anyone who has one of the BIG BAD boys lay down any more impressive of a number at the track than the "smaller" cams out there?
A bigger cam will have driveability problems that a smaller cam wouldn't. Also, require higher idle, produce worse gas milage, have rougher idle, and MUST HAVE PCM programming, since surging and other problems are sometimes evident.
I know that these symptoms are not going to occur in every car. Why use these monsters if there is no track data that would back up their stature?
I constantly see people posting on here asking about cams, and one of the first thing asked is, "how does it sound or lope at idle"? WHO FREAKING CARES??!! The point of installing an aftermarket cam is to get the most E.T. out of it AT THE TRACK IMO, not some "impressive" dyno number!!
For the record, I still have the stock cam in my car and I am contemplating cam choices right now. Can anyone convince me WITH TRACK E.T. PROOF that something larger than a 222-224 duration is superior?
<img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Let's roll this back a bit. Frankly most of the folks out there have 218-224 duration camshafts. Why is that... Well, the early stuff was all over the place. I myself owned what a GTP #4 cam back in 98-99. It was 232/232//116. My car did not perform with that cam. It was too radical at that time in a few ways... We didn't know what the goods and bads were for the LS1, we didn't know where these cars made peak hp etc...
A few years later, and big cams are becoming more accepted.
In general, a big cam changes everything.
Moderate cam performs well with a moderate converter, factory gears, and can work with basic programming.
Big cams needs BIG rpms, big converters, beefy clutches for 5500 clutch dumps, and big gears... All of those things help the motor get to the sweet spot, we call it the powerband. From peak torque to peak horsepower, that's the sweet spot. Heck, you might have a big cam that needs that 4500 stall and 4.10 gear. If you don't get that big converter in there, the car might be a turd out of the hole since it will take too long to hit peak tq.
There have been some MMS 229 cars that have run good, there have been other cams and project cars out there too. Not everyone needs a 232/232//112 camshaft in their car.
IMO 218-226 is a nice range to be in for duration.
I like the 218 stuff for mild applications. Won't lope like crazy, might be able to avoid programming, nice SOTP increase. Will totally pass emissions without any drama on a 114 LSA.
Now, the 229 stuff? Need gears, converter etc., to make it work.
Here are the cams I have run since 1998...
232/232/116 GTP
222/224//113 Comp
236/240//111 Comp XE
228/228//111 Comp XE
242/242//114 Lunati
Any of the stuff over 224 duration is gonna need some gears (for the most part). If you move peak HP from 6000 to 6450 there needs to be commensurate increase in stall speed and gearing.
Combination is everything. This is not just an LS1 thing.
I think that we are intake restricted to a point where the gains from the really big cams are not as dramatic as they should be... I think that will change as we help the motor get more air in on the intake side.
[ March 06, 2002: Message edited by: Pro Stock John ]</p>
My cam is going to be 226/234 112LSA and 557/575 lift. That is considered a big cam by some but it isnt really that big when you think about it.
I also have a 4400 stall and 4.11 gears with spool. I am not as concerned about street manners as the normal person. If I can get it to idle decent and make great power from 4500-6600rpm I will be very happy.
Compression of your heads, head flow numbers intake and exhaust and at what lift, vehicle weight, plus gearing and converter selection all play a large factor in your cam choice.
Hope this helps,
Chris
If you stuck one of these stocker cams in a street driven LS1, it would be a handfull...but, it will make MUCH more power than any of the mild cams we're running in our street cars and with enough converter and gear, the ETs would be much quicker. Al Corda runs 10.0s with the same race weight as the Pepper. Just think if he had Raughammer's awesome Stage II MTI heads? He's go even quicker.
Now if that desn't seem very impressive, consider Judson Massingill's 418 ci LS1. He runs a 260/264 duration cam...now that's what I'd call big. I'd also call his 138 mph ON MOTOR big too. Yes, bigger can be better...you just know how to use it.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Come on buddy, you guys asked for proof...I gave it to you...now you want to throw the streetability angle into it...see, that's the rub. You can go faster with a bigger cam if you're prepared to turn it tighter and live with the driveability issues, but there's no such thing as a free lunch...cams are all about compromises. A 222/222 single pattern cam has a lot fewer compromises than a 238/238 cam in the same motor (all other things being equal). It's the law of diminishing returns. Once you get past a certain point, the gains become less and less. It seems, once you go past 224 in duration at .050, the gains, while there, start to diminish fairly rapidly (we're talking stock displacement, hydraulic roller cammed applications).
As far as my car's concerned...I've got some changes being done to the car right now and then there's some tuning to do. Once it's all sorted out I will report back to you...and yes, I will have an answer to you valve float problem by then.
Patrick
I hear what you are saying Patrick, but my point is comparing a stock eliminator to a street/strip car is comparing apples and oranges. Lets talk about factory computer, stock displacement, heads/cam cars with large cams vs. small cams.
Where's the beef??
What is the main purpose for split duration cams? Is it just to help out the exhaust flow? If someone has awesome flowing exhaust port would he still benefit from more duration on exhaust. Would the benefit be less compared to someone with bad flowing exhaust port?
Let's say you had a good cam. 222/222 .550 .550 114LSA You wanted more out of it, but not that much. What would you change? Would 226/226 .550 .550 114LSA be better then 222/226 .550 .550 114LSA? Let's say heads flow good both intake and exhaust. You don't want too much overlap right? So isn't adding just exhaust duration better then adding both intake and exhaust?
Now put in a big cam with say...4.71 gears...and it may very well tear up the track...(hint hint) <img src="gr_grin.gif" border="0">
[ March 07, 2002: Message edited by: Fireball ]</p>
<strong>
</strong><hr></blockquote>
God I hate when people try to tell ME what the point of putting a cam in MY car is. Some of us DO care about what a cam sounds like. some want it nice and quite for a sleeper, some (like me) want it at least slightly obnoxious, some want it to sound like the world is coming to an end. But if there are people asking OBVIOUSLY it matters to them right? Are peopel not allowed to mod there car for any reason other than stricly making it the fastest it can be at the racetrack? why do you care what reasons other people put cams in their own cars for. are you now the self appointed rule maker for cam swaps? and what exactly does sound have to do with track numbers vs dyno numbers?
