?? For those who removed TM from the PCM?
What did this do for you in the 1/4?
I've seen some runs where my timing has actually gone to -4 on some shifts. What kind of improvement can one expect?
Thanks!
<img src="graemlins/gr_guns.gif" border="0" alt="[guns]" /> TM!
'99 Red T/A FireHawk #397 11.78@115.2
Major Mods: SLP LT's with ORP's - B1 Cam - GTP Heads - LS6 Intake - ASP U/D Pulley - Custom 8pt Chromoly Cage - DTS Custom 373 Rear - 315 Nittos (26x10.5x16 E/T Streets)
[ March 07, 2002: Message edited by: Sparky ]</p>
Thanks!
IMHO, would not turn it off completely since other functions also use it like traction control, active handling, A4 trannies.
I would do some PCM scans and do hard launches, record Delivered torque and then using LS1-edit set the max torque value in PCM to just above the highest value you see in traces.
If G.M set the max torque value to 350 ft/lbs and you added mods that would increase torque, then anytime you spike over the max value T.M is kicked in and it costs you performance.
While your calibrating the PCM with LS1-edit also tone down knock and misfire they also eat performance when you really need the power.
[quote]Originally posted by Sparky:
<strong>What did this do for you in the 1/4?
Thanks!
[ March 07, 2002: Message edited by: Sparky ]</strong><hr></blockquote>
Thanks!
It is Torque Management. It is in all the A4's. It can steal torque from you car. More towards the 2000-2002's.
Torque Management (TM) is a function that allows the PCM to react to reduce performance when the PCM believes it is feeling too much load on the drivetrain, trannie, and of course those of us with C5s that have other functions an F-body does not have.
Its a way PCM can monitor and determine if timing or reducing amount of gas injected to reduce power.
If you have a PCM scanner, monitor Delivered Torque and if you see negative numbers when your in fuel trim cells 0-19, then T.M has been called on.
[quote]Originally posted by 2001CamaroGuy:
<strong>what is a TM? I have never heard of this? I have a 2001 Z28, MM6, but no traction controle. Do I have it?
Thanks Guys
Chris</strong><hr></blockquote>
Thanks Guys
7 Second Club
[quote]Originally posted by Team ZR-1:
<strong>While your calibrating the PCM with LS1-edit also tone down knock and misfire they also eat performance when you really need the power.
I was wondering, what tables do you edit to go about this. Say I want to desensitize the knock sensors, make them have less impact on the timing curve. What would I change? I am not sure what I am looking at here with the knock retard and decay tables.
Thanks for the replies.
Yep, I agree. Bump the stock 350 number up just above your actrual peak.
I've seen timing at shift go as much as 5deg negative with total timing during my runs off as much as 4deg.
Mark
Mark
Mark you know a TH350 is calling your name...no TM ever lol <img src="gr_images/icons/wink.gif" border="0">
[quote]Originally posted by JNorris:
<strong>I saw around .1 improvement in the 1/4. I had MTI do the programming.
John</strong><hr></blockquote>
Post your model year please.
[quote]Originally posted by Matt98SS:
<strong>Mark you know a TH350 is calling your name...no TM ever lol <img src="gr_images/icons/wink.gif" border="0"> </strong><hr></blockquote>
No . . . can't . . . must . not . . . overdrive . . . . $$$ . . . . .
There! I'm all better now. No thank you very much - at least not yet <img src="gr_grin.gif" border="0">
Mark
Mark
Forget removing TM from the PCM, I just removed the PCM... <img src="gr_images/icons/wink.gif" border="0"> With LS1EDIT you guys should have no problem doing !tm now though.
