T-rexish cam.. DDing, and what else can I refresh while in there?
As I've been speaking about for a while now, I'll be swapping an LS1 into my LT camaro. Before I drop the engine in, I'll be swapping the cam out(well, the shop will). The engine will have around 60k-80k miles on it, what are some weak points that I can them refresh while the engine is apart?(well parts around, or changeable during a cam swap). What are the weak points of the LS with a high revving engine(6800ish?).
I should be getting another car so I don't have to put all these miles on my LS, but I might need to drive it alot sometimes.
should be out of a 2000-2002 ss.(not that the ss matters). I mostly meant which weak points in the block/heads should I change that aren't normally changed in a cam swap.
LS1 Tech Administrator
If you keep the automatic, you should seriously consider installing a high stall torque converter before you add the cam. A T-Rex with a stock converter is slower than stock cam in the quarter mile (ET-wise).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
