Big cam vs small cam
Old Mar 10, 2002 | 04:42 PM
Terry Burger's Avatar
Default Big cam vs small cam
I want to get a list going of the idle vacuum of the various sponsors camshafts, at say 900rpm. This will let us compare them and figure out which cams are big and which cams are small. Someone saying "it idles good" isn't good enough anymore. <img src="gr_images/icons/wink.gif" border="0"> Let's quantify this.
I'm going to go pick up a vacuum guage at pep boys and I should be able to post the idle results on my 229v2 camshaft soon.
Old Mar 10, 2002 | 04:53 PM
LS1derfull's Avatar
Default Re: Big cam vs small cam
Great idea, but keep in mind computer tuning will make a difference in peoples results, and this can alter readings making them harder to compare.
Old Mar 10, 2002 | 06:24 PM
LS1derfull's Avatar
Where is every body on this? This should be usefull for every body on here, just about. <img src="images/icons/rolleyes.gif" border="0">
Old Mar 10, 2002 | 06:37 PM
OK I checked my idle at 900rpm (verified on scan tool), in and out of gear. In gear I pulled 14.5psi, out of gear I pulled 15.5psi. This is with the MMS 229v2.1 camshaft, and custom tuning.
Let's see where all the other cams fall! Come on guys...
Old Mar 10, 2002 | 06:43 PM
spawn's Avatar
That sounds like a big cam. How big are the heads?
Old Mar 10, 2002 | 06:45 PM
LS1derfull's Avatar
Those readings are in inches of vacuum not psi right?
Old Mar 10, 2002 | 07:11 PM
In inches. It pulls better vacuum than the 215/224 cam in my 355 LT1 engine. I remember back in the day I used to get 8-9" with the comp 306 in an 11:1 350 LT1... <img src="gr_images/icons/wink.gif" border="0">
Heads are ported truck heads. I guess no one else wants to post their vacuum? Afraid of finding out your cam is a lot bigger than you think?
Old Mar 10, 2002 | 07:18 PM
LS1derfull's Avatar
I think you are pulling close to stock motor vacuum, thats impressive! Granted that would be at a lower rpm, but still good.
Old Mar 10, 2002 | 07:27 PM
JS's Avatar
JS
18.5 in gear and about 17.5 outta gear at 925idle Happy now Terry.
Old Mar 10, 2002 | 07:30 PM
Great lets get some more info in! How about that TR 224 cam JS? Or maybe that "216" cam you had? Ever check those?
Did you just check your vacuum now JS? Or had you done it before and remembered?
[ March 10, 2002: Message edited by: Terry Burger ]</p>
Old Mar 10, 2002 | 07:47 PM
JS's Avatar
JS
Terry once again u insist on me not having a 216 cam well believe what u wish but thats what was in the car.The TR cam nope nerver checked the vacum.
Yes I rember checking it after the LS1 edit tune.Pretty good for a 224-580 cam,Huh.
JS
Old Mar 10, 2002 | 07:48 PM
Scalpel's Avatar
Just curious, what's the idle vacuum for stock cammed cars? This may help in comparing idle ability to the stock cam.
Old Mar 10, 2002 | 08:02 PM
[quote]
<hr></blockquote>
I won't know until I see some numbers from the other 224 cams out there. <img src="gr_images/icons/wink.gif" border="0">
spawn's Avatar
What lift on that 229v2 cam? What LSA? Can you show some dyno graphs. Is there a 229v1 cam? What info can you give us on that?
Old Mar 10, 2002 | 08:05 PM
Right now I'm just trying to see how other cams idle. There is a 229v1 camshaft that had a much worse idle, and made about the same power I believe. I think the lift is in the 570 range. The only dyno chart I have, I made in photoshop and excel. <img src="gr_images/icons/wink.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
Old Mar 10, 2002 | 09:13 PM
spawn's Avatar
You are running with an EWP, who makes it? How mutch did you gain with it? ET and trap speed?
Old Mar 10, 2002 | 09:17 PM
VINCE's Avatar
Shorty Director
My question is who has heads milled 50 thousands and have they checked the P/V clearance? If so, have they determined what the biggest cam they could run with stock pistons.. This is the million dollar question..
Old Mar 10, 2002 | 09:21 PM
spawn's Avatar
Tery, how much compression are you running? At high altitude you can get away with 12.5/1 or more. High compression would explain the 900 rpm idle with a 229 cam.
Old Mar 10, 2002 | 09:36 PM
JimMueller's Avatar
Do I need a vacuum gauge for this or will Autotap give me the numbers? I presume MAP is what I want to monitor on the scantool?
If it's just MAP, mine averages 14.2 while in cell 19. Minimum was 10.6, max was 30.1, median was 13.9. 484 traces.
My cam is a Comp 218/226 112, with Fastchips tuning.
[ March 10, 2002: Message edited by: JimMueller ]</p>
Old Mar 10, 2002 | 10:02 PM
[quote]
<hr></blockquote>
Burger motorsports. It was worth ~7rwhp from 5000rpm-7000rpm.
I used a vacuum guage to measure mine. I don't know how it reads in autotap. I assume autotap gives you the value in pressure. Can someone help us convert?
I run 11.3:1 CR, and 26 degrees timing @ WOT on ~93 octane gas.
