Special thanks to JmX
Old Mar 21, 2002 | 09:01 PM
Phate's Avatar
Default Special thanks to JmX
Thanks for all of the "How To" pages on your site. I used them to install my LS6 intake, heads, cam, and new 2001 oil pump!
Also, on my other post you were right about the pushrod length <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks Again,
Scott
<small>[ March 21, 2002, 09:01 PM: Message edited by: Scott 98Z M6 ]</small>
Old Mar 24, 2002 | 05:20 PM
Xsta Z 28's Avatar
Default Re: Special thanks to JmX
Ditto that! I 've been working with Mark on the same install. The info has been EXTREMELY helpfull!
Thanks
Old Mar 24, 2002 | 05:28 PM
1madss's Avatar
I also used his and Raughammers site when I did my H/C/I install. Thanks guys for going through the trouble to document these installs. it makes it much easier to do these thing ourselves when you have good documentation to work from.
Mark
Old Mar 25, 2002 | 02:33 AM
geniusjester's Avatar
question about the oil pump install...it all looks pretty straight forward, but when u get to the part of removing the pick up tube out of the pump, how did u guys go about doin it?
Old Mar 25, 2002 | 10:06 AM
jmX's Avatar
jmX
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
geniusjester, if you've read through my directions and they dont make sense yet, they will when you get to the part you are asking about. The pickup tube is just held on by one bolt, and as long as you loosen all the oil pan bolts you'll have enough access to it. After that bolt is free, the tube just pops out and you can slide the oil pump off the crank.
Old Mar 27, 2002 | 05:35 PM
sounds simple enough...im sure i can do it. oh yea..about the oil pan bolts. Do i remove all of them completely or just loosen them enough for the pan to drop down so i can access the tube? hehe..sorry for the questions, i just want the install to be a no brainer as much as possible <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 27, 2002 | 06:18 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
I've read over them a few times now, in preparation for my heads/cam/headers/intake coming up in june. Very thorough and informative! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> A+
Old Mar 27, 2002 | 07:04 PM
98blackSS's Avatar
I've used his pages a couple times as well. People don't realize sometimes how much work that is and I certainly for one appreciate all his work. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
