Why use 5.3L heads?
Old 01-18-2007, 11:50 AM
shudog's Avatar
Default Why use 5.3L heads?
Looking into a budget heads/cam buildup to make around 400hp/400tq using something like a 224 cam for fun on the street. I see alot of the sponsors offer nice deals on ported LS6 heads - what's the advantage of running 5.3L heads instead?
Also, what's the difference between stage 1, 2, 3 when talking about head packages?
Old 01-18-2007, 11:55 AM
brad8266's Avatar
The 5.3L heads ahve smaller combustion chambers which bumps up your compression.
Stage 1-3 are just the level of porting/polishing. 1 being a basic port job and 3 being a very precise port job.
Old 01-18-2007, 11:57 AM
mxmatt137's Avatar
The 5.3L heads often flow over 300cfm at a budget price making them an excellent choice for a low cost build up. The advantage is just that, great flow at a low cost. I believe the main reason for the cost difference is the availability of the 5.3L head. As for the different stages, that usually refers to the amount of work done to the head. In other words, stage 1 is the basic head with some CNC work or hand porting. Stage 2, 3, etc. would imply more work and greater performance.
Old 01-18-2007, 12:02 PM
PREDATOR-Z's Avatar
Stages usualy are relative to the size of the valves running in them, and the degree of porting.
In general: (this may vary from one vendor to another)
Stage 1 are stock valved
Stage 1.5 are 2.02 int and stock exhaust
Stage 2 are 2.02
Stage 2.5 2.04 or 2.055
Stage 3 are 2.08 or bigger (usualy bigger bore as well)
Old 01-18-2007, 12:57 PM
Ace$nyper's Avatar
Also the smaller conbustion chamber alters flame travel, or am I wrong with wedge head ohvs?
Old 01-18-2007, 01:05 PM
Jordan S.'s Avatar
I've always wondered this too. But you can mill any head to get the combustion chamber size you want to bump compression.
Are they good performing heads compared to a 243 or are they just good bang for the buck?
Old 01-18-2007, 01:17 PM
brad8266's Avatar
They perform great compared to other heads out there. Bang for buck, no. TEA stage 3 5.3L heads are 2100, not cheap.
Old 01-19-2007, 09:30 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We offer the PRC Stg 2.5 5.3l heads for $1199! This package gets you proven performance, dependable air flow, and consistancy that's second to none. We use a Newen single point cutting system to guarantee perfect valve jobs everytime for crazy consistant flow numbers. Checkout a video of the seat & guide machine on www.texas-speed.com in the cylinder head section.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-29-2007, 06:49 AM
shudog's Avatar
so... why use 5.3L heads over LS6 heads? Seems like they are priced very similarly...
Old 01-29-2007, 07:05 AM
brad8266's Avatar
if I had to buy a new head set, it would be LS6's and then just mill them to up compresion. There is no advantage to 5.3's if you mill LS6's. If you dont mill LS6's the 5.3's will yield higher compression due to chamber size.
Old 01-29-2007, 10:08 AM
bad6as's Avatar
if both are milled to say 60cc wich would have more ptv
227/232 lsk/xer on a 109+0
is that cam being used with mls gaskets
Old 01-29-2007, 10:13 AM
mike#9's Avatar
The LS6 should.
Old 01-29-2007, 10:15 AM
bad6as's Avatar
i just dont want to fly cut if the 109+0 wont fit ill get a 110+0
Old 01-29-2007, 11:25 AM
mike#9's Avatar
What lift cam..that will come into play as well
Old 01-29-2007, 11:26 AM
bad6as's Avatar
i think its this
228/232 .635/.595
Old 01-29-2007, 11:47 AM
HotWhipT/A's Avatar
I'm trying to learn too. My understanding is all of said above plus the 5.3s have smaller runners than the LS6's, but flow the same. So, if the LS6's are milled down to where the 5.3's chambers are, the 5.3's should make more TQ because the smaller runners increase the velocity of air. Right? I just want a TSP 228R cam, I won't have any PTV clearance problems....so it seems as the 5.3's are better for me.
Old 01-29-2007, 12:03 PM
Studytime's Avatar
Guys keep in mind what came out first. The 5.3L head or the LS6 head? The LS6 head has revised D-shaped exhaust ports, a more efficient chamber, better designed runners, AND a decent short side radius to port on.
Ben T.
Old 01-29-2007, 12:11 PM
bad6as's Avatar
Ben T.
Old 01-29-2007, 02:53 PM
Thimble's Avatar
Ben T.
What's the advantage to D-shaped exhuast ports?
I've never seen a header with D-shaped tubes or flanges, wouldn't the ideal setup be a port-matched seamless transition between the port and flange?
Old 01-29-2007, 03:03 PM
Sharpe's Avatar
This, post #10, is the reply to the question.
