How does LSA affect Compression Ratio?
Old Jan 20, 2007 | 07:27 PM
AJay's Avatar
Default How does LSA affect Compression Ratio?
Like the title says:
Can someone explain to me what affect going from a 115 LSA to a 118 LSA would have on compression ratio?
Old Jan 20, 2007 | 08:21 PM
Patrick G's Avatar
LS1 Tech Administrator
Changing LSA won't change static compression but it could change dynamic compression. Mostly depends on if the LSA change moved the intake valve closing point. Exhaust valve opening changes can affect torque as well. Giving a well rounded answer to your question might take 1000 words.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 20, 2007 | 08:40 PM
N4cer's Avatar
The simple answer: The higher LSA will decrease the dynamic compression in almost every case that applies to the cams and cars on this board.
But Patrick is right. There's no simple answer.
Old Jan 21, 2007 | 08:45 AM
AJay's Avatar
So if I understand correctly the LSA may affect the intake closing point. If my IVC goes from 45 ABDC to 47 ABDC my dynamic compression ratio would be reduced.
Is that it?
Old Jan 21, 2007 | 10:05 AM
N4cer's Avatar
Basically, that's the main part that you should be concerned with. Yes.
Old Jan 21, 2007 | 10:09 AM
comp builder's Avatar
Changing the LSA won't affect your static comp ratio, unless your are running you piston to valve clearance at the minimum, at which point you would either be backing up the pocket depths, or deepening them, depending on which way you go with the LSA. Even when you do this it normally makes minimal changes to the comp. ratio, since p to v clearance only changes about .007" to .010" per degree of advance or retard.
Cory
Old Jan 21, 2007 | 10:11 AM
N4cer's Avatar
Of course a cam doesn't affect static compression. It changes dynamic compression.
Old Jan 22, 2007 | 07:24 AM
AJay's Avatar
It's dynamic compression that I'm concerned with. I'm going to a baby cam for my "wife driven grocery getter" and I'm concerned that I might need to shave the heads a bit more to maintain DC.
Old Jan 22, 2007 | 10:59 AM
Patrick G's Avatar
You may find that a smaller duration cam with a wide LSA gives you more DCR than the cam you're running now. It all depends on the valve events chosen.
__________________
Old Jan 22, 2007 | 11:10 AM
AJay's Avatar
Thanks!
