Buying Camshaft Kit , need help
Should i buy it with the mods that i have or should i buy something before it.
What else should i buy w/ the kit?
i understand that i will have to get the pcm programmed.
thanks!
Your gonna need headers to really complement the cam. I suggest LT or mid length (Mac or Bassani). I see you live in Cali, remember only shorties are a go out here.
I always think about doing things now and worry about the consequences later...which I know is bad, but figured that "money talks" and I should have no problems with emissions <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Pcm programming all depends on what cam you get. You can get away with drilling out the TB a little with a 114 lsa, but for 112 I would get programming. Before my programming my car wouldn't idle for ****. Now, she runs perfect..only stalling out sometimes in reverse.
You should also consider a good tq converter.
BTW where in Cali do you live?
peace
<small>[ April 21, 2002, 02:12 PM: Message edited by: SidewayZ-28 ]</small>
hooker LT headers
and yank t.c.
those are what i was looking at
any comments or other suggestions ?
thanks
rialto , ca
or....
Total Engine Airflow (TEA) CNC Ported GM LS1 Stage II heads: $1799
with CompCams 918 springs installed
http://www.totalengineairflow.com/pr...head/index.htm
_____________________________________________
CompCams camshaft Lobe Profile #3712/3712
218/218 .563/.563 114 LSA
High Lift Xtreme Energy (you have an A4, you dont need any more duration except for bragging rights)
Yank 3,000-3,500 Converter
Shorty Headers (your in Cal) with JetHot coating and Carsound high flow Cats installed in Y-Pipe
(retain all your O2 sensors)
LS6 Intake Maniflod
New timing chain
Shift points set to 6,300
Rev Limiter set to 6,700
Delete Misfire Detection
Set Fan turn-on at 190 degrees
Increase Idle 100 rpm
Delete EGR code (If you purchase LS6 intake manifold)
[If] you have the heads milled .030", you can use stock length hardened pushrods with the above cam...
WHY? This high lift cam will have a slightly smaller base circle than your factory cam requireing longer pushrods, however, having the heads milled .030" will require shorter pushrods.... Becomes a "tit for tat"..... Use stock length CompCams pushrods.
<small>[ April 26, 2002, 07:29 AM: Message edited by: Kimchee and Rice ]</small>
