382 All-bore for Road Race application
I'd like to be in the 400+ RWHP range with a serious eye towards reliability. One thought is an all-bore 382, stage 2 heads, and a cam with a mid-high power range. Hopefully with the extra cubes I could go with a little less lift on the cam and not beat the hell out of the valvetrain.
Thoughts or other ideas?
Basically a 382 stroker would cost you right around the same price as a 382 Big Bore. The only difference would be that you would be paying for a real strong 4" stroker crankshaft rather than a re-sleeved big bore block.
I recently had ARE build me a 436ci (4.100 bore x 4.125 stroke) and the torque curve is nucking futz!! I can't wait to get this thing out on a few roadcourses this summer.
<small>[ April 27, 2002, 01:27 AM: Message edited by: MattG ]</small>
I would even consider doing a built 346 with dry sump oiling (cost more, but if you're planning on a lot of fast sweeping turns it may be worth it, and you could definently get 400 rwhp out of it.
J.
I have a 96 Z-28 6M, and after much reseach in my search for Horses I decided (as you said) to go with reliability.
Of course I have an LT-1. I went ahead and purchased a 383 LT-4 longblock with Lunati 4340 Assemblies and cam and AFR heads.
Its pricy to do so but I went ahead and purchased a brand new block. Since I had no away of knowing the condition of my stock block till it was pulled.
To make a long story short, I think you can get as much power N/A as you can Supercharging a stock LT or LS1. And as I mentioned I felt it is much more reliable. Once you upgrade the Fuel Injectors, Fuel pump, Ingition, PCU programing and all the bolt-ons like Headers,cat-back, C.I.A., MAS, Throttle body, etc. A 383 can easily make 500 horse.
I got mine with 9.1:1 Compression and an appropriate cam for later supercharging.
It is a 2 bolt block coverted to a 4 bolt splain caps. ("bullet-proof"). So I should be able to handle a higher PSI blower at a later date.
At that point I think 700-800 Horses is plenty <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
BTW the engine came from Dallas Exports http://www.strokermotor.com thanks to ROB.
and ran me about $7,000. which isnt all that more than the Vortech-LS1-aftercooled supercharger plus labor. And much less likley to eat a stock piston. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Honestly I dont know that the do brand new LS1 blocks. But if you can somehow get your engine to Texas I promise you they are the most friendly people and tech service I found in my seach for a 383.
I hope this helps.
BlueWs6@aol.com
later
Jeff
