O2 Sensor and Spark plugs.
Old Jan 27, 2007 | 12:27 PM
Texas_WS6's Avatar
Exclamation O2 Sensor and Spark plugs.
Does anyone remember the part number for the O2 sensors that we use with the long tubed headers on a 2002 trans am? If I remember right I think they are off the 2001 Corvette but I can not remember if it is the front or rear sensor. They are the ones with the longer leads and they should have the internal heaters.
Also, I can not remember which NJK plugs to run with Nitrous. I have been doing a search but with no luck yet.
Thanks guys.
Scott
Old Jan 27, 2007 | 12:32 PM
brad8266's Avatar
NGK TR6 plugs , O2 sensor is Bosch 13111.
BTW all OBD2 compatiable sensors are heated, not just these ones.
Old Jan 27, 2007 | 12:34 PM
Texas_WS6's Avatar
Thanks for the quick reply. I am heading out to the parts store now.
Old Jan 27, 2007 | 12:36 PM
brad8266's Avatar
the stock number for the TR6 is 4177, take both numbers with you.
Old Feb 1, 2007 | 02:42 PM
neoakira3's Avatar
how about this insted of o2 sensors with headers they make ls1 gm shorting caps to bypass o2 sensors yay!!!
Old Feb 1, 2007 | 10:14 PM
Blk97WS6's Avatar
thats for the rear, you cannot bypass or delete front o2s.
Old Feb 1, 2007 | 11:41 PM
99kamarokid's Avatar
are buying the corvette ones any better than re-using stock ones???
Old Feb 2, 2007 | 12:08 PM
Blk97WS6's Avatar
alot of people run the corvette o2s(myself included) because of the issues with the stock o2s and LT headers. Since the o2 is moved further back with LT headers, the o2 does not heat up as much, causing it to read incorrectly. the corvette o2s will take care of this problem.
Old Feb 2, 2007 | 02:45 PM
is there a certain year corvette i would get it from thats better???
Old Mar 9, 2007 | 10:51 AM
pantz28's Avatar
Just go with the 13111's. They were used on multiple year Corvettes.
Old Mar 9, 2007 | 11:00 AM
tuffass's Avatar
Thanks guys.
Scott
Hey buddy. I just posted an ad for sale locally in austin for some brand new 02 sensors. I bought them 2 weeks ago and i'm now putting TSP's true duals on so i dont need them. I bought them for 78.00 each and will sell all 4 for 250.00.obo free shipping. I'm kicking myslef in the *** because I thought i'd need them. I cant return them because I've already installed them, even though they have less than 100 miles on them.
Let me know if your interested and maybe we can work something out.
Old Mar 9, 2007 | 11:02 AM
tuffass's Avatar
TSP said to not use 02's with they're TD set up. They suggested to have the codes deleted. Can you only remove the rear ones? Does they're set up come with drilled holes for the fronts?
I'm lost.
Old Mar 9, 2007 | 11:11 AM
Griswold's Avatar
I'm lost.
You can not run the car without front o2 sensors. They should be on the collector of each header. The rear ones are the ones that need to be deleted. You can either run o2 sims or delete the codes via hptuners or ls1edit.
Old Mar 9, 2007 | 01:47 PM
tuffass's Avatar
Okay, I remember now that you said they are in the collectors.
Old Mar 9, 2007 | 10:32 PM
Blk97WS6's Avatar
I'm lost.
Yup, i was referring to the rear o2s. Now hurry up and get your cam done
