Lets talk about oil
What weight do you run? What climate are you in? How often do you change it? (I think TTR changes every 15 passes <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> ) Do you use a power adder?
If you have a built motor, how many quarts do you use? What filter are you using (1/2 quart or full quart?)
Anything I've forgotten?
J.
Southern semi tropical climate
Change it after 1500miles or a couple trips to the track
No power adders. Yet. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Oil pressure is 45psi at idle hot and 70+psi at WOT ( 2001 pump)
I haven't noticed any oil usage but I change it often.
I'm going to try out Royal Purple next oil change.
I live in illinois, so its winter/summer... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I usually change it at 2000-2500 miles... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I will soon be running a power adder... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I use the FRAM filter, stock size...
And I put 5.5 quarts in the motor...
i went road racing and a couple highway trips and a drag racing trip on the M1 10-30 and no oil loss yet <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> its a little thick, but it seems to be working well.
oh yea, i live in IL but dont drive in the snow. i do drive when its freezing out though, lol. No power adder, stock CUI.
i have jiffy lube change it because work pays for it (hey, would YOU turn down free oil <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> - i watch them change it though <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
<small>[ April 28, 2002, 08:18 PM: Message edited by: DriveATransAm ]</small>
J.
20W-50
MD (Mid Atlantic)
3000 miles
Not any more <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
PF-44 (car sits too low for the longer one...scares me <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
I would definitely stay away from 5w30 under most conditions. The only time you should run it is in the winter, and only if it gets below 32F often in your area. Otherwise 10w30 is your best bet. It's the most stable oil, it uses little or no thickeners in it in order to span that viscosity range. With 5w30, it actually starts out as a 5 weight oil (and 10w30 starts out as a 10 weight) with thickeners added to keep the oil from thinning out at high temps, so over time it will shear back to the lower number. With a 5w30, it is not as stable, so it shears back quicker. Those extra thickeners end up creating more friction inside the engine too, especially when they start to wear down.
I've been asking around about the new Super Syn Mobil 1, and the oil experts are all saying it is testing very well in the wear category, it's a lot better than the TriSynthetic stuff. Those of you that were having oil burning problems with TriSynthetic might want to give this stuff a try.
I've also been hearing amazing things about Valvoline's new Maxlife oil as well. It's a dino oil, however it contains a very high content of anti wear additives and detergents, as well as a seal conditioner. So higher mileage engines can eliminate minor leaks with this stuff. It won't last as long as synthetic though, so don't try out extended intervals with it.
With a good synthetic I would recommend 5k oil changes (makes things simple to remember) Changing it at 3k is just a waste, since the oil is not worn out by then.
When I say good synthetic, I'm not talking about Castrol, Valvoline or Pennzoil, as all of those are hydrocracked, which means instead of using a group IV fully synthetic base stock, they use a highly refined petroleum base stock known as group 3. So you're paying synthetic prices in order to get a dino oil. Not good, and they won't hold up to the longer intervals as well.
AC Delco PF-59 filter
hot, humid climate
change every 2,000-2,500 miles
naturally-aspirated
ran Castrol 10w-30 dino for the first 5,000 miles
has never burned any significant amount of oil; typically no more than 1/2 qt. for each oil change, even with the beating I give it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ April 29, 2002, 09:13 AM: Message edited by: Trevor D ]</small>
<strong>That 20w50 is costing you a few horsepower Fireball, and running 10w30 won't lessen your engine's life at all. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Agreed but I'm pushing 71K miles on my motor and I'm spinning the snot out of it now...any extra oil pressure is my friend at this point <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Fairly warm (FL)
Change about every 4K miles
No power adders
AC PF59 filter
6 qts add @ change
Occasionally use maybe 1/4 pint of oil but not necessarily when run hard????
51K miles
I think I'll step up to 10w next time. I heard Mobil 1 was on sale at Wally World <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
J.
I think synthetic oil is a waste of money. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Climate: mild/temperate
Change interval: depends on wear (i.e. spectrographic analysis) - never more than 12 months (mileage stays low enough to where it isn't a factor for me). Using a good quality synthetic without analysis I'd stick with 3-5 months/3000-5000 miles under normal conditions.
Power Adder: nope
Filter: UPF-58
Quantity used: 6 quarts
<strong>currently adding N20 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are you going to step up to a thicker oil when you start spraying?
Nice avatar <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
J.
ac delco pf44
as soon as 382 comes in wit modded oil pump I will be going to a 10w30 synthetic wt oil. maybe stay with mobil 1 or going to royal purple.
currently oil gets changed every 2000 miles or 2 months which ever is first.
oil consumption has never been an issue and I hope it continues to be that way.
