cam swap starting issue
Old Jan 28, 2007 | 05:39 PM
cav101's Avatar
can u get a video clip?
Old Jan 28, 2007 | 05:58 PM
Boosted 99 TA's Avatar
yeah everytime it fires instant then dies instantly right aftre..i will try to get a vid in a few minutes.
Old Jan 28, 2007 | 06:14 PM
eallanboggs's Avatar
You should hear the fuel pump cycle for 2 sec. at KOEO.
Old Jan 28, 2007 | 06:15 PM
fuel pump is kicking on i can hear it
Old Jan 28, 2007 | 08:07 PM
cav101's Avatar
it really sounds like the vats
Old Jan 28, 2007 | 09:23 PM
would having the battery out for 2 months cause the VATS to do this. i will try to get a vid tonight or tomorrow.
Old Jan 28, 2007 | 09:36 PM
keliente's Avatar
Did you set the timing up right?
Old Jan 28, 2007 | 09:37 PM
yaeh the timing is right.
Old Jan 28, 2007 | 11:08 PM
cav101's Avatar
resetting the vats is an easy procedure, from what i can recall, just try it and see what it does. access to a scanner that u could hook up to check everything else?
Old Jan 29, 2007 | 06:52 AM
would anything about the VATS show up on a cheap auto zone scanner you think? that way i know for sure whats goin on.
Old Jan 29, 2007 | 12:58 PM
Anyone???
Old Jan 29, 2007 | 02:48 PM
  #32
FBGSU02's Avatar
well mine did the same thing when i put my cam in. i had to send my computer off and get a tune on it and turn all that security crap off. even though mine is a huge cam that still might be your problem
Old Jan 29, 2007 | 03:49 PM
  #33
Asmodeus's Avatar
with a scanner you can set the vats code to "none" and that should turn it off so you can determine if that's the problem. I can't remember which code it is off the top of my head, but I know I saw it searching this problem.
Old Jan 29, 2007 | 07:35 PM
  #34
i just hooked up a scanner and it didnt show any codes...could the VATS still be the problem?
Old Jan 29, 2007 | 07:41 PM
  #35
ArcticZ28's Avatar
I'm pretty sure a scanner won't pick up vats codes. I could be wrong, but I'm pretty sure, especially a scanner from autozone or something of the likes. You'll more than likely need to scan it with a Tech-II or something on that level.
Old Jan 29, 2007 | 07:58 PM
  #36
thats what i figured...i will have to try to find some around here wtih a good scan tool. thanks
Old Jan 29, 2007 | 09:20 PM
  #37
K5tpi's Avatar
Your problem is the VATS system! There is a pass key or tamper modual problem and you have been locked out of the pcm, Remove the pcm and send it to Pacific Fabrication in Morgan Hill ca. The guys there can reflash it to elimnate this issue. Check out PacifcFab.net
Old Jan 29, 2007 | 09:52 PM
  #38
are you sure its the PCM....what about the BCM i thought that had something to do wtih it as well. clear me up on this i never really looked into this whole VATS thing to much. how much do they charge usually?
  #39
Old Jan 31, 2007 | 05:49 PM
  #40
Asmodeus's Avatar
Sorry I said scanner, I meant EFI Live or HP Tuners etc. And yeah, the BCM is part of it. Search BCM and see what pops up.
