cam swap starting issue
Old Jan 27, 2007 | 11:10 PM
Boosted 99 TA's Avatar
Default cam swap starting issue
Just got done installing my new cam. I went to start the car and it fires up instantly but then it dies. What do yo uguys think is causin this problem. thanks
Old Jan 27, 2007 | 11:14 PM
brad8266's Avatar
What cam is it? Try giving it gas.
Old Jan 27, 2007 | 11:19 PM
its a tu1 cam 225/225 duration .581 lift 113+1 lobe sep.
Ya tried giving it gas, it starts up fine it just immeaditley dies after. Giving it gas doesnt make any diffenernce
Old Jan 27, 2007 | 11:27 PM
brad8266's Avatar
Check the plugs, wires and fuel system first. That size cam should stay running.
Old Jan 27, 2007 | 11:32 PM
its not running it fires up and then dies
Old Jan 27, 2007 | 11:37 PM
ArcticZ28's Avatar
Cam and crank sensors both plugged in and not pinched somewhere?
Old Jan 28, 2007 | 12:29 AM
yeah it is plugged in
Old Jan 28, 2007 | 01:09 AM
but it still doesnt work
Old Jan 28, 2007 | 01:33 AM
JRracing's Avatar
Check the fuel pressure with a gauge.
Old Jan 28, 2007 | 01:34 AM
JRracing's Avatar
And crank the engine with the coils un hooked. check oil pressure also.
Old Jan 28, 2007 | 02:47 AM
well the ignition should be fine i mean the car fires up but just dies instantly..
Old Jan 28, 2007 | 10:46 AM
TWISTEDTA's Avatar
Needs a basic tune, mine did the same thing. Well mine started, ran for a little bit then after if warmed up it idled like crap and died... wouldnt start back up. Needed a basic tune.
Old Jan 28, 2007 | 11:23 AM
cav101's Avatar
does it sound like its running good, then something kills it?
Old Jan 28, 2007 | 01:38 PM
it sounds real good when it fires....it sounds like all cylnders fire for just a quick second and then it dies instantly...Seems like th ecar would still run without a tune its not to big of a cam..
Old Jan 28, 2007 | 02:40 PM
Asmodeus's Avatar
I know exactly what your problem is.. I've seen this exact same thing before, and it had NOTHING to do with fuel, spark, anything. You tripped your vats.
It's your anti-theft system. I forget exactly how to reset it so you can run the car. I know if you searched on this, you'd find your answer though.
Try a spare key, check fuses, have a new key made, could also be the ECM.. but that's the area you're having trouble.
And good luck with the car hope she runs scalded
Old Jan 28, 2007 | 03:01 PM
hmm that is interesting. i wonder why it would do that tho.
Old Jan 28, 2007 | 03:13 PM
erikthegoalie's Avatar
yes this happened sometime back with a guy in this board and his truck with a new motor in it (i think)
it didnt start....it was VATS, he had to reset it...search and you shall find
Old Jan 28, 2007 | 03:18 PM
The security light turns off when the key is on...could it still be VATS?
Old Jan 28, 2007 | 04:53 PM
ShevrolayZ28's Avatar
I think not.
Check for fuel pressure at the schrader valve on the fuel rail. And can you hear the fuel pump buzzing?
Old Jan 28, 2007 | 05:37 PM
cav101's Avatar
the vats is what i was getting at. Will it start good everytime, no matter how many times u try it in a row? Repeatedly start/run shortly/stop? now that the vats light goes off, that may mean it is not it, but i would try resetting it anyway.......however, i had my car without power for over a month, and it didnt trip anything, so its weird that you should have to reset it. Try some of the other suggestions listed above also, we'll get it figured.
