GM Performance Parts LS1 to LS6 Conversion Package
http://store.summitracing.com/partde...2&autoview=sku
The car is my daily drive in the summer. I want something reliable but with more power. I was thinking about this kit and headers. I also have a nitrous kit that I might install for occational track use.
Jason
Jason
http://texas-speed.com/shop/item.asp...d=204&catid=47
look into something like the above...i'm sure others will chime in with their own thoughts ... good luck!
As far as a cam goes, you can get something bigger than the LS6 cam to give you more.
maby: Thunder racing CheaTR Cam or A GT2-3 lingenfelter cam ,smooooth stock sounding.
Jason
The March issue? I'm still waiting for that one to be delivered.
Jason
The gains you would get from the setup you posted would be extremely minimal for the amount of $$ and amount of work required to put it together.
Pacesetter Headers, Full-Length, Ceramic Coated
http://store.summitracing.com/partde...5&autoview=sku
Hedman Street Hedders, Full-Length, Ceramic Coated
PRC Stg 1.5 5.3L Heads
Texas Speed 228R Camshaft
Ported LS6 Oil Pump
Rollmaster Single Roller Timing Set
Heads and Cam GM Bolt / Gasket Kit
TOTAL: 1,931.97
That's about $100 more than what you were looking at on SummitRacing. You'll put down quite a bit more power with something like this. You will still need to get the car tuned and have the emissions "taken care of". The package listed above includes some items that you don't NEED. You can get an LS2 timing chain instead and save about 80 bucks; get a normal ls6 oil pump and save 40 bucks, etc. There will be other things you need, mainly tools!!! which will add to the cost.
I just bought the TSP torquer v.2 camshaft and it cost me 1200.00 with tools, fluids, parts, etc. I am accounting for everything - down to the 10 extra retainer locks and 2 oil pump pickup tube o-rings and 8 qrts of oil. So, factor in another 1100 for the heads and you are looking at about $2300 when it is all said and done.
You will be INFINITELY happier if you choose an aftermarket package instead of the GM package. And you will be quicker than a stock Z06
(but how many of THOSE exist, lol)If you have an A4 - As "brad8266" said - a stall and headers (and gears) would do quite a bit as well, but you'll probably pay more for all that.
This is off topic but I just wanted to say VERY NICE times on the GTP, I bought my Z28 after my 00 GTP got wrecked. I miss that car sometimes it used to supprise people just how fast a 4 door sedan could be.
Jason
