Valve Spring ? please help.
Old May 12, 2002 | 07:17 PM
ShiznityZ28's Avatar
Default Valve Spring ? please help.
i have JPR S2 heads on the way. w/ a thunder cam. i currently have isky springs and titanium retainers. i was gona put 918's on. but now am thinking double springs. 4?
1. will the 918's work with the titanium retainers i already have?
2. will the retainers i have work with the comp cams double springs part #63-978-16.?
3. how much better are the 918's than the iskys?
4. how much better are the doubles?
thanks for the responces in advance.
<small>[ May 12, 2002, 07:42 PM: Message edited by: ShiznityZ28 ]</small>
Old May 13, 2002 | 08:06 AM
Default Re: Valve Spring ? please help.
Come on i know sombody here is a spring expert.
Old May 13, 2002 | 10:47 AM
bigeller's Avatar
In my opinion you won't need the double springs having read what I've read. I think you could successfully use the heavy duty slp valvesprings.. They are cheap to boot! Check the link.. They are good to .600 lift.
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
Old May 13, 2002 | 01:43 PM
NoGo's Avatar
For starters, I have no clue what Iskys, but I can give you a little help with the other questions.
If the Iskys were the a direct replacement for the stock then, yes. I recieved one of the first shipments of 918's that came with some seriously oversized retainers. I used them and they worked fine for 20k miles, until I went with a double setup.
I doubt it. Remember though, with the double spring set-up you will most likely have to machine the spring seats in your heads to properly fit the spring. That, and you may end up machining your rockers as well... total pain. <img border="0" alt="[fight]" title="" src="graemlins/gr_punch.gif" />
Like I said, I have no idea what iskys are, but I can tell you that the 918 is a great spring. I beat the absolute snot out of mine: highspeed runs, missed shifts, you name it. They held like a champ. You should have no problems running 918's and the thunder cam.
In my opinion, unless you are looking to upgrade to a monster cam, or plan on spinning the hell out of your motor, the double springs are an overkill. They look cool though <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck with the setup.
Old May 13, 2002 | 01:50 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NoGo:
<strong>For starters, I have no clue what Iskys, but I can give you a little help with the other questions.
Good luck with the setup.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thanks for the infor. the isky springs are sold by thunder racing they at one point were suposed to be awsome. but JPR had a set break last week and i just wanted to find out if maybe they have a short life or what. thanks for the info and if anyone else has an idea send em my way.
Old May 14, 2002 | 02:48 AM
FAST99Z's Avatar
What spring do you recommend for someone who has ARE stage 2 heads/cam with 11/32" valve stems. The 941s are not up to the task.
Old May 14, 2002 | 07:48 AM
NoGo's Avatar
The 918's should be up to the task, max .625 lift, 7500 rpm. I have yet to hear of one breaking. I'm sure you will have good luck with them as well.
I run a double spring setup with my ARE Stg II H/C. Sure, it was a total pain to get it to work right.... had to clearance a bunch of stuff, but I enjoy the piece of mind. That, and my valvetrain won't be a limiting factor as I upgrade... which is done very often.
Old May 14, 2002 | 11:28 AM
GTP LS1's Avatar
The 918's won't work with the ARE Stage II heads with the 11/32" valve stems.
Old May 14, 2002 | 01:33 PM
NoGo's Avatar
My bad. The 918 will not work with the older ARE Stg II H/C with the 11/32 valves (I should have read more careful). The newer packages have 5/16 stems.
In that case, if you were already running 941 springs, use the K Motion K-750 spring. They should be a direct replacement for the 941's.
Old May 15, 2002 | 01:03 AM
FAST99Z's Avatar
The K-750s fail just as often as the 941s
Old May 15, 2002 | 07:36 AM
ok the titanium retaineres on the iskys will not work with the 918's. so i will have to buy a set. anyone want a set of isky springs and retainers?
Old May 15, 2002 | 08:14 AM
NoGo's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FAST99Z:
<strong>The K-750s fail just as often as the 941s</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I only know of a few failed K-750 setups (unlike what I have heard regarding the 941). I doubt you would have any problems with them
All springs break <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Even doubles. In fact, I am investigating a possible broken double right now.
