Reverse torquer cam (the other side of the coin)
Old Jul 1, 2007 | 10:47 AM
  #121
FDLS1's Avatar
Originally Posted by PREDATOR-Z
Not worth it because the cam you have makes decent power and your car is so light.
That's true, low end power just cooks the tires on this car....maybe I should be looking for a cam that is more peaky. Something that would make crazy power from 4000-7000+rpm
Old Jul 1, 2007 | 10:54 AM
  #122
PREDATOR-Z's Avatar
I got one for you but you'll have to flycut since you milled your heads.
231/240 .643/.608 114+4 LSA (Custom grind Comp lobes)
Old Jul 1, 2007 | 11:02 AM
  #123
FDLS1's Avatar
How much power would this give me?? gains over what I have? So, pull the heads, flycut the pistons, and buy a new set of 0.040 cometic gaskets...sounds ok to me. Total $500-600 in parts, and just my time.
Old Jul 1, 2007 | 12:13 PM
  #124
PREDATOR-Z's Avatar
another 30+rwhp properly tuned
Old Jul 1, 2007 | 10:28 PM
  #125
JaSSon's Avatar
Originally Posted by Websy21
Hey Jasson sweet set-up man, those TEA 1.5's are they the ls6 or 5.3's? Thanks
They are the 5.3s I got for a measly $1300. The car has been working great for 3yrs now.
Old Jul 2, 2007 | 09:24 AM
  #126
Websy21's Avatar
I really am considering the TEA 1.5's, Fast 90/90 and X1, but after doing the math it adds up close to the price of an ATI system. To me the supercharger is less hastle and will give more power and drivabilty. Probably better on fuel? What's your thought?
Old Jul 2, 2007 | 10:06 AM
  #127
PREDATOR-Z's Avatar
It is about 1/2 the price of a FI application.
Heads 1500, Cam 400, Fast 1300 about $3300 in parts. (with gaskets and fluids)
Old Jul 2, 2007 | 11:22 AM
  #128
Websy21's Avatar
There is always extra costs though, unless you skip the timing chain/oil pump and don't get upgraded injectors and fuel pump???? Question, what level of horsepower with a H/C setup can you get away with no fuel upgrades? On a 2001 with 55,000 miles would it be retarded not to get the timeing chain/oil pump? With the TEA/X1/Fast would it be most necessary? Skip the them and the fast that's over 2000
Old Jul 2, 2007 | 11:34 AM
  #129
FDLS1's Avatar
LS2 timing chain $30
ported LS6 oil pump $120
FMS 30# injectors $200 or less in the for sale section all the time
Old Jul 2, 2007 | 03:14 PM
  #130
Websy21's Avatar
found a good deal on bosch 42lbs, would these be too big with a cam only or h/c install
Old Jul 2, 2007 | 03:26 PM
  #131
john563's Avatar
I have 42lb in my Head,cam ,intake.No problems here
Old Jul 2, 2007 | 03:36 PM
  #132
Websy21's Avatar
stock pump, no regulator. Just needed a tune after install. I am trying to get away with not doing them if possible?
Old Jul 2, 2007 | 03:38 PM
  #133
Websy21's Avatar
Originally Posted by gillbot
Mine made 399.2 rwhp with stock untouched heads and crappy mac mid headers, the info is here: https://ls1tech.com/forums/dynamometer-results-comparisons/476349-tr230-224-a4-dyno.html
Hey gillbot, do you got an underdrive pulley on your car?
Old Jul 2, 2007 | 04:28 PM
  #134
john563's Avatar
Now he does
Old Jul 2, 2007 | 05:46 PM
  #135
Websy21's Avatar
Hey Gillbot I am getting ready to make my order, what lsa did you go with? 111?
Old Jul 2, 2007 | 09:11 PM
  #136
Websy21's Avatar
Is it possible to run a cam like this with no tune, just to get it to the dyno after I install myself? I have a couple hour highway drive then through a city. Good ole Canada, don't have dyno's down the street like most of you
Old Jul 2, 2007 | 11:17 PM
  #137
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I just got some green tops in the for sale section for $200 shipped. You just got to keep your eyes out for things in there as it moves so quickly.
Old Jul 4, 2007 | 10:31 PM
  #138
gillbot's Avatar
When I made 399, it did not have an underdrive pulley. I haven't gotten a good dyno run since I got the pulley on and the tuning dialed back in. I really want that 400 number. I know it doesn't mean anything special but dammit I want it!
I believe mine was cut on a 110 but I don't recall. I'd have to dig out my cam card to be sure but off the top of my head it was either 110.4 or 110.2 lsa.
Old Jul 16, 2007 | 09:24 PM
  #139
cws T/A's Avatar
Originally Posted by Studytime
There is a jpeg floating around with an overlay of a 224/224 112 and a 230/224 and the torque graphs are IDENTICAL below 5,000 RPM.
Close enough
Old Aug 14, 2007 | 06:28 PM
  #140
bad6as's Avatar
so when would a 230/230 or 232/232 come in compared to a 232/230 or 230/232
