Fel-Pro #1041 head gaskets ?
Old Jun 3, 2002 | 10:29 AM
SJH's Avatar
SJH
Default Fel-Pro #1041 head gaskets ?
Anybody using them?
Old Jun 4, 2002 | 10:04 PM
XtraCajunSS's Avatar
Default Re: Fel-Pro #1041 head gaskets ?
I have them on my new engine. Will fire it up next week...
Shane
Old Jun 5, 2002 | 02:14 AM
wicked 98z's Avatar
Where did you get them?
Old Jun 5, 2002 | 08:57 AM
ShiznityZ28's Avatar
I would like more info on these. my napa gaskets are still not in <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Jun 5, 2002 | 10:21 AM
SJH's Avatar
SJH
They are very nice composite gaskets with silicone beads around the water jackets. Pre flattened copper o-ring inside stainless fire ring with a very large bore size of 4.135". Which is just what I needed for my enlarged 73cc chambers <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
041" Compressed thickness and 9.4cc volume.
I got mine from Summit.
Steve
Old Jun 5, 2002 | 11:49 AM
GTP LS1's Avatar
ShiznityZ28:
I tried to order Napa gaskets a few weeks ago and after waiting 3 weeks I was informed that they could not get them. At first one side came in and the other side did not. Then instead of the other gasket a shock came in instead. Then they said it will be a few days until the other side came in. Then after I called and complained, they did some clicking on the computer and said that the other side is unavailable. This was at the Gaithersburg store.
Old Jun 5, 2002 | 01:43 PM
horsepower's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SJH:
<strong>Anybody using them?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">are you sure on that part number - 1041 does not seem to exist?
Old Jun 5, 2002 | 01:47 PM
I got my 1041's from Thunder Racing. I don't believe it is a regular stock item but I'm sure they can get you a set.
They have a .041" compressed thickness and a 4.135" bore. The compressed volume is 9.4 cc's.
Shane
<small>[ June 05, 2002, 01:49 PM: Message edited by: XtraCajunSS ]</small>
Old Jun 5, 2002 | 02:49 PM
SJH's Avatar
SJH
yes 1041 is the part number. I have a set sitting on my bench.
I should make it clear that they are a solid steel core with a composite coating.
Stock gaskets are perforated steel cores with graphite coating and have no 0-ring inside the fire ring.
Looks like you can forget about getting any GM gaskets separetly now.
I tried a few days ago to get 6.0 MLS gaskets but even those are now only sold in kit form with the TTY bolts.
Seems Napa is now no longer a source either for the old Victor graphites.
The larger bore on the fel-pros will work fine with stock bore ls1's.
Mr.Gasket also has a MLS gasket in 3 large bore sizes.
I went with the fel-pros as they seal well and this type gasket has held up pretty good for me in the past.
You also get .011" tighter squish with these gaskets over the older stock graphites which is a good thing <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Steve
<small>[ June 05, 2002, 02:51 PM: Message edited by: SJH ]</small>
Old Jun 6, 2002 | 12:01 AM
NoGo's Avatar
Funny, napa was the only place that I was able to get my headgaskets from. Took them over 1 weekend to get them.
It was the GM parts folks that I was having problems getting the gaskets from.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 6, 2002 | 12:07 AM
i ordered them may 24th and they said 3 days now there saying friday. guess i will wait. does felpro make stock size gaskets if so whats the part #?
