Bearings
Old Feb 8, 2007 | 09:35 AM
NC98Z's Avatar
Default Bearings
I have driven the pure hell out of every Chevlolet I ever owned. Big blocks, Small blocks,305s,350s,402s,427s and I have never had one spin a bearing on me. Now in the last 6 months I have had two different engines the last being a brand new LS6 Vette crate motor spin a bearing. Whats up with these bitchs? If I have to put another short block in would I be better off to get a iron block 408? This **** is getting very old very quick.
Old Feb 8, 2007 | 10:17 AM
BLKWS.6's Avatar
What level oil (how many qts?) do you run in them and what brand/weight?
Old Feb 8, 2007 | 10:45 AM
Z'mnypit's Avatar
Yeah something isnt right. Are you assembling the motors? What kind of oil presure do you normally have?
Old Feb 8, 2007 | 11:37 AM
CraZee ZO6's Avatar
bearings are not a common problem as far as I know with these lsx motors.
Old Feb 8, 2007 | 11:38 AM
brad8266's Avatar
If you are revving very high with stock rod bolts that could be part of your problem.
Old Feb 8, 2007 | 01:08 PM
NC98Z's Avatar
Both motors were built by Chevrolet.Oil pressure was running between 60 and 80 psi. I have been running Valvoline 5w-30. I always have filled until the dip stick was right. The crate motor only had 3500 miles on it when she let go. And my shift point are set a 6300. All na no turbo, no snails no NOS. At least I got a warranty with it. Go figure.
Old Feb 8, 2007 | 01:09 PM
brad8266's Avatar
^^ Damn, I dunno whats up then.
Old Feb 8, 2007 | 01:31 PM
98-LS1's Avatar
I beat the **** outta my 98 and they evidently suck as far as oiling is concerned, so far I haven't had one bit of a problem. Knock on Wood..
