gear driven ls1
Old Feb 9, 2007 | 08:02 PM
Npak's Avatar
Default gear driven ls1
anyone have a gear driven crank/cam instead of using a chain? if so whats the company u got it from and all the goodstuff
Old Feb 9, 2007 | 08:17 PM
SSTowerman's Avatar
Interesting. My Dad had his Harley converted to gear drive. Mostly because the chain tensioner wears out fast on Harleys. You darn sure can hear the gear noise from it. Never thought about it for the LS1 motor. I might be inclined to stick with a LS2 chain or double roller because of the cost/benefit factor.
Old Feb 9, 2007 | 08:18 PM
Npak's Avatar
if i go w/ a double chain setup, i gotta change the pump/crank gear and seperate the oil pan from the block a half inch. can this be done w/ that crossmemberbelow the oilpan there? love the noise of a gear driven.
Old Feb 9, 2007 | 09:10 PM
Npak's Avatar
http://cgi.ebay.com/ebaymotors/Cloye...spagenameZWDVW kinda like that? will that work w/ a sl1?
Old Feb 9, 2007 | 09:16 PM
brad8266's Avatar
I havent yet seen a gear driven set for an LS1. There is a chain to belt conversion though.
Old Feb 9, 2007 | 09:35 PM
N4cer's Avatar
You'd have to tune out your knock sensors.
Old Feb 9, 2007 | 09:36 PM
Npak's Avatar
why tune them out and how?
Old Feb 9, 2007 | 09:38 PM
brad8266's Avatar
Just desensitize them, by tuning the attack and delay tables in the PCM. Multiply the attack table by .xx and the decay table by 1.xx
Red's Avatar
Red
I saw the Pete Jackson set for LS1 (Jegs or it was Summit) mag.
Old Feb 9, 2007 | 09:48 PM
N4cer's Avatar
Which in effect tunes them out. Exactly. Listen to Brad because I sure don't know the wording. I don't tune.
Old Feb 9, 2007 | 10:53 PM
brad8266's Avatar
It doesnt tune em out completely, just makes them not so sensitive. I desensetized mine by 10% to stop my false knock i was getting.
You had the right idea, at first i just thought you meant to tune them out completely.
Old Feb 10, 2007 | 12:46 AM
mvvette97's Avatar
I had two sets of those in an old 350 and on both sets the needles bearings went bad in the dual idlers. They only lasted about 8000 miles
