High Performance Hyd Lifters?
Old Jun 13, 2002 | 11:09 AM
Terry Burger's Avatar
Default High Performance Hyd Lifters?
Other than the Comp R lifters, are there any other high performance lifters I can get? Are the Cranes any good? I'm looking for something that can stand ~400# open pressure and 7500rpm. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 13, 2002 | 01:39 PM
Colonel's Avatar
Default Re: High Performance Hyd Lifters?
They are the only aftermarket LS1 lifters that I know of and are what I use.
<small>[ June 13, 2002, 01:39 PM: Message edited by: Colonel ]</small>
Old Jun 13, 2002 | 01:44 PM
How much do they cost? Do you think they are better than the compR lifters?
Thanks!
Old Jun 13, 2002 | 01:45 PM
Fireball's Avatar
I'm taking a gamble and throwing in the crane OEM replacements. for 170 dollars can't hurt but I wouldn't try 400 lbs on them <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jun 13, 2002 | 01:46 PM
So does Crane make a hipo lifter or just that OEM replacement?
Old Jun 13, 2002 | 01:55 PM
Fireball's Avatar
only saw the OEM replacement
Old Jun 13, 2002 | 02:21 PM
Colonel's Avatar
Wait a minute. I may be confused. Now that I think about it I can't remember if I have the Comps or the Cranes. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I'll find out.
Old Jun 13, 2002 | 02:43 PM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fireball:
<strong>I'm taking a gamble and throwing in the crane OEM replacements. for 170 dollars can't hurt but I wouldn't try 400 lbs on them <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto I am going with the crane replacement lifters from summit.
Old Jun 13, 2002 | 02:50 PM
Air21's Avatar
the comp cams are on back order. The company that they buy them from went out of business, go figure. I canceled my order because ther were 1500 sets on back order
Old Jun 13, 2002 | 03:46 PM
BADZ's Avatar
Moderator
I got my fresh set of comp lifters ready to install, no worries here...
Old Jun 13, 2002 | 09:51 PM
NoGo's Avatar
I just put in a set of cranes.
ARE Stage II H/C .554 Lift (I have no clue what # lift)
They sound like a sewing machine, but don't collapse like the stockers do.
They look nothing like the stockers
Old Jun 16, 2002 | 02:21 PM
Fireball's Avatar
my cranes just came in...look identical to stock to me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 16, 2002 | 02:47 PM
MelloYellow's Avatar
Are there more than 1 type of Crane LS1 lifters? OEM and anti-pump? I'd give up on the Comp R's.
Old Jun 16, 2002 | 11:09 PM
NoGo's Avatar
<strong>my cranes just came in...look identical to stock to me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Strange, somebody else said the same thing to me. The lifters that I recieved from crane were nothing like the stockers. They are basically a metal cylindrical tube with a small ring and hole about the center. You can't see but just the very tip of the roller. They were slightly lighter than the stockers, and had the oil fill hole on a different axis as well. They look basically bomb-proof. When I find the box, I will give a part number.
They installed fine, but are as loud as hell. The car sounds like a sewing machine.
Old Jun 16, 2002 | 11:33 PM
FWIW, there are 2 styles of OEM lifters. I can't describe them well, but 1 has a complete cage over the roller area, the other has parts cut away on the cage with less material. The newest OEM doesn't have a full cage and are weaker. Started in '01 from GM??
