Good heads for torquer v3?
Old Feb 13, 2007 | 03:37 PM
pHEnomIC's Avatar
Default Good heads for torquer v3?
I wanted to do some head reasearching and I want to narrow down my choices. Basically, the cam is pretty big with lots of lift so i have to be careful with ptv clearance. Car has full boltons.
Stats are 231/234 .644/.598 111lsa
Id like to make the most power possible. What goals should I look for and what aim the compression to be at?? I realize there is more to heads than flow numbers and dynos are very misleading as well. What heads can i not use since the cam is big?
It is a street car but I love to take it to the strip and stuff sometimes.
Planning on keeping ls6 intake, will possibly use nitrous with the heads and upgrade the fuel system.
Old Feb 13, 2007 | 03:43 PM
Cantalope Kid's Avatar
ALL NEW PRC LS6 CNC Ported Heads
http://texas-speed.com/shop/item.asp...d=649&catid=40
ALL NEW 220cc PRC 5.3L Stage 1.5 Ported Heads
http://texas-speed.com/shop/item.asp...d=132&catid=40
Get these as a cam/heads package if you can, much less inepensive. Also mention you are an LS1Tech.com member...Some sponsors offer discounts to members over their internet pricing. NOT ALL though so ask!
Old Feb 13, 2007 | 03:46 PM
c0ncEpT's Avatar
Its duration that causes PTV problems
Old Feb 13, 2007 | 07:25 PM
pHEnomIC's Avatar
The lift is also an issue. Since the valves get opened soo big, they are open bigger throughout the entire duration. You have to be careful when choosing heads with this type of cam.
I already have the cam installed so won't be doing a head/cam package purchase.
Old Feb 13, 2007 | 10:43 PM
BREWS02WS6's Avatar
TTT, Im interested too
Old Feb 14, 2007 | 09:39 AM
These issues are not a problem if you get the Texas Speed heads I mentioned above...No fly cutting pistons (unless you are getting the head face milled down for some reason)...just bolt on and have fun! Best answer would be to simply just call Texas Speed.
Old Feb 18, 2007 | 02:44 PM
onebadZ28's Avatar
I'm interested in this subject also
Old Feb 18, 2007 | 09:22 PM
bad6as's Avatar
i to wonder how the 5.3s would do and how the ls6's would compare to the 5.3s.
ptv clearance and power
Old Feb 18, 2007 | 11:43 PM
hammertime's Avatar
Larger diameter valves in the 5.3 heads are going to eat up some of your PTV clearance. LS6 will leave you with more room, especially if you have to mill them to get the compression where you want it. I didn't see a CC size listed for either head.
Old Feb 19, 2007 | 09:27 AM
Brian @ Texas Speed & Performance's Avatar
LS1Tech Premium Sponsor
I'm running the T3 with the PRC stg 1 heads. The combo works VERY well together. The car makes plenty of power everywhere for me. There would be plenty of clearance with the Stg 1 heads or the 5.3 heads. We can set the 5.3 heads to clear the MS3 so the T3 will have no PTV problems.
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
Old Feb 19, 2007 | 09:39 AM
SSippi's Avatar
Brian, you got a dyno of the power your making with the T3 and PRC stage 1 heads?
Old Feb 19, 2007 | 10:12 AM
SSippi's Avatar
I did a search in the dyno section and found his posting back in sept 06. Here is a link to his dyno. http://www.texas-speed.com/briansgraph.jpg
Old Feb 19, 2007 | 11:45 AM
pHEnomIC's Avatar
What intake is being used and what are the other stats on this build? Also what type of dyno is it? That is most likely the setup I will go with.
Old Feb 19, 2007 | 01:12 PM
SSippi's Avatar
Well I would guess it is an LS6 intake since he has an 01 and a ported TB. You know If I had a fast intake it'd be in my signature line. His other mods are listed in post number 10 of this thread.
Old Feb 19, 2007 | 01:46 PM
cws T/A's Avatar
https://ls1tech.com/forums/showthrea...=568797&page=1
