GM CNC Ported LS6 Head?
I would like to know what the compression would end up being and what length push rods should be used.
They sure look a deal, I would like to know more too!
CNC'd 02 LS6 heads from SDPC
<small>[ July 05, 2002, 10:52 AM: Message edited by: Ryan ]</small>
Price: $990.50
Part # 12480176
Best buy on the planet! Unbelievable performance from fully CNC ported cylinder heads. Some of the best low and mid-lift numbers we have ever seen from a stock size valve. These heads will flow over 200cfm at 0.300" lift and 290+ at 0.500". Fully assembled with the 2002 Z06 light-weight valves and the new '02 valve springs. These heads have been milled 0.055" to bring the combustion chambers back down to approximately 60cc. Care must taken to check pushrod length and proper intake installation when using these cylinder heads. Price is for each cylinder head.
What compression does 60cc imply?
I think stock LS6 heads are around 64cc and 10.5 compression.
also
What's the deal with the push rods and intake?
<strong>LPE ports these heads.
I think they are $1800 each.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">did no one look at the link? 990 each.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
I think they are $1800 each.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">According to the link it's $990 per head or about $2000 for both LS6 heads ported.
LS6 heads are already proven to make power over LS1 heads without porting or milling. With the lighter valves, you don't have run as heavy a spring, maybe pick up a few ponies from drag.
I'd guess these would make great daily driver heads with gains all across the board. The down side being the higher compression.
Traditionally, GM Performance parts are great street parts with high quality, and few drawbacks.
I would guess your two problems with these would be the much higher compression (still run good on 91?) and getting custom pushrods. The combination of the longer valves, and the .055" mill job will probably require a much shorter pushrod.
But... I really don't have a clue. Should be good "sleeper" heads. Put in a '02 Z06 cam (blasphemy), leave the stock exhaust manifolds on the car (match the ports), and you could pass for stock. IF someone asks, just say "I'm running OEM parts...", as you push 360+rwhp. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
GMpartsdirect charges: $2,175.60 for 2 of them including S&H ($362 for freight alone). What a
f@%ng ripoff gmpartsdirect is!
If these LS6 heads are ported by LPE and they are $990 each or right at $2000 for both, why are the LS1 heads advertised on his website $1500 each or $3000 for the pair? In other words, LS6 heads are $1000 cheaper? Is that much more work done to the LS1's? Are valves that much?
I'm confused.
