Broken head. (56k warning)
Old Feb 17, 2007 | 02:55 PM
BlackSuperchargedLS1's Avatar
Default Broken head. (56k warning)
A little backround. Heads & cam have been in for around 4k miles. Along with heads & cam were PRC dual springs, chromemoly pushrods, new lifters & ported ls6 oil pump.
I had just pulled out of a gas station & was driving normal. Speed was about 45 mph. The car revved up 3-4k rpm, I let off the gas & put it in neutral. The rpms & mph kept steady even after letting off the gas. There was a squeaking sound for a few seconds along with loud tapping and a pop. After that the car died.
Now for the pics.
Old Feb 17, 2007 | 02:57 PM
Tony Orlando's Avatar
Crap...That hurts to look at. Any ideas of the cause yet?
Old Feb 17, 2007 | 03:01 PM
skipperbisket's Avatar
ouch...wtf happened?
Old Feb 17, 2007 | 03:03 PM
nofearracing28's Avatar
Whoa...what heads are those??
Old Feb 17, 2007 | 03:06 PM
DaddySS's Avatar
It will be interesting to see the under side of the head and to learn who's heads those are.
02BLKWS6MD's Avatar
Are those the TSP LS6s? I heard that was happening to them.
Old Feb 17, 2007 | 03:07 PM
I have no idea what caused this to happen.
They are PRC LS6 CNC'd heads from Texas-Speed.
Old Feb 17, 2007 | 03:09 PM
frodo84's Avatar
Not throwing stones at anyone, but do a search. That is not the first time this has happened.
Old Feb 17, 2007 | 03:12 PM
Hell'sChariot's Avatar
that sucks!
Old Feb 17, 2007 | 03:24 PM
Yeah I did that right after I posted to try to find out what caused it. I see i'm not the only one this has happened to.
Old Feb 17, 2007 | 03:25 PM
Not everyone has been on the forums forever
Old Feb 17, 2007 | 03:44 PM
frodo84's Avatar
I was talking about not throwing stones at the supporting vendor that supplied the heads.
Old Feb 17, 2007 | 03:46 PM
brad8266's Avatar
That sucks man.
Old Feb 17, 2007 | 03:51 PM
mr2guru's Avatar
Just call TSP on monday, it was a known issue. Im sure they would take care of it.
Old Feb 17, 2007 | 03:53 PM
SIC LSX's Avatar
to much porting making them weak???
Old Feb 17, 2007 | 03:55 PM
brad8266's Avatar
That would be my best guess.
mr2guru's Avatar
Basically. Part of the reason they moved to a 230cc runner instead of 237cc. They explained the issue in the other thread.
Old Feb 17, 2007 | 04:52 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
No worries man call me on Monday morning & I'll replace them with a set of the all new smaller runner ls6 heads. I'm making sure & swapping out any of the old none welded casting guys to the all new ls6 head if they have any issues.
The new ls6 & new 5.3l heads have never had one failure so we'll just swap you over so you'll be good to go.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
soulless's Avatar
Do you know if this is the new version or the old version of the head?
Old Feb 17, 2007 | 04:55 PM
That has to be the old version of the head, I redesigned with the smaller runner for better throttle response & to eliminate the possibility of this happening.
__________________
Jason
2005 Twin Turbo C6
