4.25" Bore now available..!
Old Apr 17, 2002 | 07:06 PM
Ozzydragracer's Avatar
Default 4.25" Bore now available..!
Jayson at MTI e-mailed us, they have three custom LS1 liners available, up to 4.25" bore! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thought before that that 4.125" bore with liners was the largest.. You all bore guys might want to call Jayson. He quoted $1,200 installed, good price IMO. were sponsored so not our money were playing with!
PSJ & NineBall, with a 4.25" Lunati crank = 482 cubic inches... Your opinion on that combo?
thoughts would be appreciated, as not a lot to spend on liners (4.25") @ $1,200 + Lunati crank (4.25") to get 482".
Thoughts guys?
This site rocks. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Cheers
Old Apr 17, 2002 | 07:45 PM
guadofreak's Avatar
Default Re: 4.25" Bore now available..!
wow
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Apr 17, 2002 | 08:06 PM
ChrisB's Avatar
Has anyone actually run these liners in a street situation? I would be curious to see what coolant consumption and strength situations are with such a large bore.
Very interesting though!
Chris
Old Apr 17, 2002 | 08:07 PM
XLR8NSS's Avatar
Adkoonerstrator
Wow!! Let me ask this. Just how much material do you need between cylinders. I thought bore spacing was only 4.4". That would only leave .15 inch of material between cylinders. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
That would make a 454 with a 4" crank. You could put some big 2.1" intake valves in and port out a Holley intake and have a monster. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Apr 17, 2002 | 08:14 PM
slow's Avatar
umm...wow is all i can say.
Thats not a lot of $$ for a large displacement Square motor.
Ryan. (dreaming that he had lots of $$) <img border="0" alt="[Z06 Corvette]" title="" src="graemlins/z06.gif" />
Old Apr 17, 2002 | 08:16 PM
Jayson from MTI recommended the 4.250" set-up. He said $1,200 gets you the liners, installed, with the block surfaced. You still have to bore & hone the liners to 4.250", which obviously he can do.
As far as bore spacing is concerned, anyone (Jayson/MTI) know the spec's on that? PSJ, or NineBall?
Old Apr 17, 2002 | 08:21 PM
XLR8NSS's Avatar
Adkoonerstrator
Here's another question Ozzy. I'm assuming the $1200 dollars doesn't include the block. You would have to supply a block. Is that right?
Also, are they selling the resleeved block seperately without having to buy the whole motor.
This sounds interesting. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 17, 2002 | 08:33 PM
XLR8NSS,
Yes, thet sell the block (used alloy LS1) separately, for a quoted $600!! (Cheap IMO) <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Or they will do yours for you. Add the cost of a bore & hone to the $1,200, & get them to do it.
And obviously, you don't need to buy a whole engine from them. This deal with 4.250" set-up is very cheap.
An 'All Bore' engine with this MTI deal works out at 411 cubic inches, for less than @$1,500, including bore/hone. Add head gaskets to that.
Thoughts on this? PSJ & NineBall?
Plus 482" with 4.25 Lunati Crank?
Cheers <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 17, 2002 | 08:45 PM
Nine Ball's Avatar
LS1Tech Co-Founder
They will be using the largest sleeves on my 434ci motor, but I am only having them take the cylinders out to 4.155" to retain a nice wall thickness for possible ~cough~ ~cough~ nitrous later. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
They haven't built any 4.25" bore blocks yet, but their machinist thinks it will be possible with these sleeves.
As for pricing, I have no idea.
As for a HUGE motor like that, I think you will hit the law of diminishing returns once you go past a certain size. I know our intakes can't feed those cubes, so a custom intake would almost be a necessity. I told MTI that I'd rather have a badass running 434ci motor than a mediocre 471ci setup. Just my feelings on that.
Tony
Old Apr 17, 2002 | 09:18 PM
SStrokerAce's Avatar
Man,
We're going to get into the water jackets porting heads to work with that. 350cfm+ would be nice with a 454+, the problem is that someone (Wilson)needs to port that Holley intake to make sure a 350cfm set of heads is actually able to get that much cfm to the cylinders. A very large T/B would also be needed, somewhere around 100mm or so. That would be good for 700+hp N/A, then I would get concerned about the wall thickness. But then again, LPE has that 427 Twin Turbo 750hp engine that holds up.
I'd like to see a 454 street engine with a hydralic roller, that would be a great daily driver after you got it working right. GM never made a 454 Camaro, but they should have!
Bret
Old Apr 17, 2002 | 09:21 PM
Reckless's Avatar
Super Moderator
Me thinks you're gonna need some pistons to go with that too! So better add about $700 for that, and another $650 or so for rods if you want those. It's not as simple as buying a prepped block and voila, you got a big engine.
Not trying to burst you bubble, it sounds like a great deal to me!
Old Apr 18, 2002 | 01:45 AM
I did not include pricing of rods/pistons as for anyone wanting to build a stroker/big bore engine, you would have to buy aftermarket rods and pistons anyway....
More input would be appreciated... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 18, 2002 | 10:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Very interesting!
I'd like to see one!
Everyone already made the points I would make.
To tell you the truth, if I could get a C5R block used I would use that next time.
Old Apr 18, 2002 | 11:15 AM
JS's Avatar
JS
John u went at it the right way.Unless u use the C5R theres a chance of colant problems.IMO its just not worth the cash to build something that might start eating coolant.
The steel block is a great idea when building a big motor.I might do one down the road too.Then if I ever wanna spray it I can w/o worries.
JS
Old Apr 18, 2002 | 03:14 PM
Terry Burger's Avatar
I'd like a 4.25x4.25 combo... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Apr 18, 2002 | 03:44 PM
Nine Ball's Avatar
LS1Tech Co-Founder
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">IMO its just not worth the cash to build something that might start eating coolant.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">w-a-r-r-a-n-t-y
Colonel is running 9s on motor with a 2-year 24,000 mile warranty. Pretty funny to think about isn't it?
Tony
Old Apr 18, 2002 | 03:53 PM
Crazyquik's Avatar
Imagine that bore with a little tiny 3.05 crank for 346 ci <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Even with a stock crank its 410. Remember back in the day when the hugest of the huge strokers weren't over what, 415?
J.
<small>[ April 18, 2002, 03:55 PM: Message edited by: Crazyquik ]</small>
Old Apr 18, 2002 | 09:03 PM
Jayson from MTI told me that the O.D. of their biggest liners were 4.350" (outside diameter), that would go 4.200" bored out, not 4.250" as previously stated from them. Just a corrdction on their part. That still puts a stock stroke LS1 at 401 cubes (All bore motor), and a 4.25" Lunati stroker which Jayson recommends with this 4.200" bore out to 471 cubic inches.. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Give Jayson a call..
Cheers
Old Apr 18, 2002 | 11:49 PM
SIR's Avatar
SIR
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> Holy shheeitt.. imagine that in a vette!! That resleeve is getting more reasonable. $1200...not to bad...wow
Old Apr 19, 2002 | 11:01 PM
1CAMWNDR's Avatar
Hmmmmmmm. 4.2" bore and a 4.109"stroke = 455.
SUPER DUTY!!!!!
Or 4.125" bore and a 3.25" stroke. That would still be only 347". You could probably stuff a 6.5" rod in there (2:1 rod stroke ratio) and might be able to get some serious rpm out of that. 8,500 rpm maybe???
Hmmmmmmm. <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
