Roller rocker install?
When i get around to my rocker arm swap is it just a simple bolt and go or will i have to have new studs threaded in like on the older chevy stuff.
Originally Posted by 2manytoys
Are guide plate a must with aftermarket rockers? Are stock studs strong enough for a .570, .590 lift cam?
If you're installing aftermarket non-shaft mount rocker arms they came with guide plates so what do you mean by "rocker arm swap"? Are you installing non OEM type rockers or are you just replacing the stock ones with more of the same type?
I have not bought any yet. Getting info so i don't find somle cheap and end up having buy a lot of extra stuff. What size studs are in LS1 heads?
