Starting with C5R block....
Old Jul 9, 2002 | 12:29 AM
  #101
z0sense's Avatar
Default Re: Starting with C5R block....
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by grb:
<strong>I believe the C5R block bore is 4.13.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">it comes 4.120 and is capible of 4.160 according to GM. Katech says the max is 4.13</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is true only if you sleeve the block. So Katech is probably right about the 4.13.
If you were to sleeve the block you would only be able to use a dry sump system.
Old Jul 9, 2002 | 01:51 AM
  #102
Will Race 4 Food's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by z0sense:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan:
If you were to sleeve the block you would only be able to use a dry sump system.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why?
Old Jul 9, 2002 | 04:28 AM
  #103
z0sense's Avatar
I assume sleeves are there to increase strength. If you bore the block out too much the cylinder walls become too thin. The sleeves increase the strength!
Old Jul 9, 2002 | 05:24 AM
  #104
<strong>I assume sleeves are there to increase strength. If you bore the block out too much the cylinder walls become too thin. The sleeves increase the strength!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">z0sense,
Thats not what I meant by 'why'. I know about the cylinder wall strength issues, I meant 'why' does it need to be dry sumped?? Why can't you run a wet sump system?
Cheers
Old Jul 9, 2002 | 10:37 AM
  #105
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
FYI our GM sponsor Scoggin-Dickey sells the C5R blocks to Katech and you can get them from SD at a very good price.
Old Jul 9, 2002 | 06:29 PM
  #106
grb's Avatar
grb
The price of the block from SD or anywhere else seems to be the same $6,195-$6,200. Heads $2,500-$2,550. Big spread.
I'm gonna meet with Lamar tomorrow. I'm sold on the block but are you guys sure those C5R heads are worth the extra trouble and expense over a properly done set of LS6 heads? Solid roller cam or not? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 9, 2002 | 07:09 PM
  #107
restoman45's Avatar
i say c5r heads are the way to go! worth the trade off... more cash and more cfm. imho
Old Jul 10, 2002 | 02:08 AM
  #108
2000LS1's Avatar
C5R heads with a bad *** custom intake manifold!!!
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
<img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<small>[ July 10, 2002, 02:43 AM: Message edited by: 2000LS1 ]</small>
Old Jul 10, 2002 | 06:21 AM
  #109
z0sense's Avatar
If you want the most you can get!
The thread was initially asking...."if money wasn't an issue, what would you use to build.....yada yada yada...."
In this case you should get the C5R heads because every little bit helps.
BTW,
I can get the 12480005 for 2310.00.......
Old Jul 10, 2002 | 11:35 AM
  #110
Colonel's Avatar
In the case of C5R heads v/s LS6 heads I wouldn't term it "every little bit."
Folks, the difference between LS6 heads and C5R heads are far more than even the difference between LS1 heads and LS6 heads. C5R heads UNPORTED flow as well or better than FULLY PORTED LS6 heads. Yes, there's that much difference. Hell, C5R heads might be more fittingly discussed in one of the power adder forums! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 12, 2002 | 02:51 AM
  #111
2000LS1's Avatar
grb, any updates???
Old Jul 12, 2002 | 07:17 AM
  #112
grb's Avatar
grb
Met with Lamar Wed. He is researching the heads. Looks like a go.
Old Jul 12, 2002 | 10:09 AM
  #113
Louis's Avatar
To put things into light,
C5R:LS6::SB2ouble hump
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
They are bare, no guides,Seats, ect. They DO require a Jesel valvetrain, and with a 2.00 intake valve they flow around 340, UNPORTED!
Old Jul 12, 2002 | 10:43 AM
  #114
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong> Hell, C5R heads might be more fittingly discussed in one of the power adder forums! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LMFAO <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 12, 2002 | 10:48 AM
  #115
ls1290's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by G2 LS1:
<strong>They DO require a Jesel valvetrain, and with a 2.00 intake valve they flow around 340, UNPORTED!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Close, they require 2.180" Intake vavles and 1.625" Exhaust valves and 1.550" seats. The heads flow like a SOB <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 12, 2002 | 11:02 AM
  #116
bdubb's Avatar
Its going to be up to the porting and the whole engine setup. As to what your motor will benefit from the C5R heads.
I would get soem really good port work done to the heads and then build your setup off the heads. I would also give katech a call. I have spoke with them a few times and I did ask a few questions about the C5R block. You can get it form them already machined for wet sump. This will keep things looking cleaner....I also remember that they said something about what size crank (stroke) it can take. They said that they can machine it to what you want at their shop and then send it to you.
It would just be good to talk to them about the setup and concerning the heads and the block. Since they are the ones that make all the C5R stuff. I would start there and then work with it.
Also like others said a FAST (speedpro/fel-pro) system should be used. I would also go with the individual cylinder control and so on. They will make everything for you to match what you have and want. The wiring harness, the software, sensors....just about everything. They are also known for having VERY hi quality. I believe they were sold a few times...but most of the original standards are still there.
Good Luck with everything.
Old Jul 12, 2002 | 11:04 AM
  #117
bdubb's Avatar
Not sure if it was mentioned already.......
but, the C5R heads...don't even have the same intake port design. They are more like the square port ford type intake ports.....Or howvere you want to describe them....
Old Jul 12, 2002 | 02:47 PM
  #118
Louis's Avatar
from what I heard, they grafted the SB2.2 intake port design in the head. quite similar though.
Old Jul 12, 2002 | 02:49 PM
  #119
Louis's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ls1290:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by G2 LS1:
<strong>They DO require a Jesel valvetrain, and with a 2.00 intake valve they flow around 340, UNPORTED!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Close, they require 2.180" Intake vavles and 1.625" Exhaust valves and 1.550" seats. The heads flow like a SOB <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have one here sitting next to me with a 2.00 valve in it, What I put in it so that I could see the back to back between both unported. Stock and C5R.
Old Jul 12, 2002 | 03:13 PM
  #120
ls1290's Avatar
<strong>I have one here sitting next to me with a 2.00 valve in it, What I put in it so that I could see the back to back between both unported. Stock and C5R.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm...... interesting. When I talked with Kaltech, they told me that the C5R should have 2.180" Intake and 1.625" Exhaust valves installed. I guess that they told me that because the Intake valve will have just enough clearance for a 4.10" bore. Maybe with a 2.100" Intake valve, the C5R heads could be used with a 4.06" bore block. Things that make you go hmmm..... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
