MMS 388 dyno results
Old Jul 13, 2002 | 03:55 PM
Chris Jones's Avatar
Default MMS 388 dyno results
99 C5. Yank 3000, 3.15 gears, TPIS headers, 388 all-bore, 229 cam, LS6 intake (unported), stock cats, B&B Touring catback, 30lb SVO injectors. Motor has maybe 100 miles, new transmission is really tight, so it will pick up some more power.
<img src="http://cjonesy.homeip.net:8080/vette/99/388dyno0001.jpg" alt=" - " />
Old Jul 13, 2002 | 03:58 PM
JP98SS's Avatar
Default Re: MMS 388 dyno results
Was that with the converter locked?
Old Jul 13, 2002 | 04:18 PM
Terry Burger's Avatar
Not bad for stock cats and an unlocked converter. I was hoping you'd pull in the 425-430 range, so be sure to redyno after 3000 miles or so! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 13, 2002 | 04:36 PM
JP98SS's Avatar
Terry...what did your H&C car pull?
Old Jul 13, 2002 | 05:38 PM
My best unlocked is around 420rwhp, but I'm also running an EWP, no cats, and open cutouts. My power band is also more top end based.
Best locked is 446rwhp. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 13, 2002 | 06:00 PM
gator's 99TA's Avatar
nice dyno numbers, but i would think that a package that resembles terries package would make in the area of 450 RWHP (esp with that MMS dyno) - draw your own conclusions. LOL
the power you actually made with that combo looks very respectable, but if TB owned it that car would make atleast 465RWHP! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> cant wait to see how it performs with 1000 miles on it! get some track times!
Old Jul 13, 2002 | 06:32 PM
With a slipping stock automatic it made 425rwhp and they hadn't finished tuning it. They said the new transmission needs to loosen up first. I'm not 100% sure, but I think this was unlocked. I'm going to check their programming with LS1edit and re-dyno with a wide band sensor once it's broken in.
Would high flow cats help much? 5rwhp, 15rwhp?
Old Jul 13, 2002 | 06:41 PM
TITAN's Avatar
Junior High Director
What kind of heads do you have?
Joe
Old Jul 13, 2002 | 07:11 PM
MMS Stage 3 heads opened up to 4.125" bore. I think they are 2.05 and 1.58" valves, could be 1.60s, don't remember for sure.
Old Jul 14, 2002 | 02:14 AM
JP98SS's Avatar
Dumping the cats could be worth 20 hp easily. I wouldn't bother with the high flow ones. On the other hand...it will really screw up your tuning.
Old Jul 14, 2002 | 02:21 AM
They have yearly emissions tests in Atlanta so I can't ditch the cats. I thought good high flow cats are pretty close to running straight thru with no cats. ??
Old Jul 14, 2002 | 02:34 AM
JP98SS's Avatar
The Stage 3 heads are 2.10 and 1.60. I think you have a set of Stage 2 heads that are opened up for the big bore motor if your valves are that small.
Old Jul 14, 2002 | 08:41 AM
onfire's Avatar
Coal Mining Director
RandomTech make a 3inch xpipe highflow cat combo that will fit your headers and greatly outflow the stock cats....should be worth 15-20hp on your set-up. You can see a pic at www.randomtechnology.com
Old Jul 15, 2002 | 12:43 AM
I had Stage 2 heads and sent them back to be upgraded to full Stage 3 heads. There was a lot of additional port work beyond just opening the bore up.
