High Idle Need Help!!
Old Feb 21, 2007 | 05:02 PM
loc's Avatar
loc
Default High Idle Need Help!!
Hello, Very new to the site and tried to search this before asking.
I have a 1998 Trans am LS1. Just today went to start it and the idle is very
high, right at 3,000 rpm. The idle will not settle down at all. The car has slp exhaust and that is it. I could use some help please. sorry if posted in the wrong forum. thanks
Old Feb 21, 2007 | 05:10 PM
SpaZMaN's Avatar
make sure the maf, iat and all those connectors are on all the way
Old Feb 21, 2007 | 07:37 PM
DONAIMIAN's Avatar
Im almost willing to bet money that its the TPS.
Old Feb 21, 2007 | 08:00 PM
1999ssls1's Avatar
I would bet its a bad tps. Thats exactly what mine did. There only like 30 bucks.
Old Feb 21, 2007 | 08:30 PM
KCS's Avatar
KCS
Moderator
Also check the little rubber hoses from the TB. One is the EECS, which wore a hole in mine.
Old Feb 21, 2007 | 10:06 PM
loc's Avatar
loc
thanks for the help I think I am going to like it here
Old Feb 21, 2007 | 10:35 PM
ArcticZ28's Avatar
Don't overlook a vacuum leak.
Old Feb 22, 2007 | 02:58 AM
DaddySS's Avatar
And check the cable from the idle/cruise control motor to the TB, make sure it is seated properly.
Old Feb 22, 2007 | 07:22 AM
bjamick's Avatar
If its a vacuum leak i think you would prob hear it sucking air. If you dont hear that then you need to check the TPS which that is prob what it is but also make sure all the stuff is plugged in all the way like said before.
Old Feb 22, 2007 | 07:55 AM
slt200mph's Avatar
I would say that it is your Throttle Position Sensor they are EZ to change and not expensive either..I had one go bad and I replaced it and the car idled fine afterward ..
Old Feb 22, 2007 | 08:14 AM
loc's Avatar
loc
would someone be able to explain where the TPS is or even a picture of it. I dont have access to a Chilton right now and am just curious what the extent of the fix will be. thanks
Old Feb 22, 2007 | 08:43 AM
slt200mph's Avatar
If you look at the top right corner or side of the throttle body you will see some wires going in there that are hooked up to a black plastic round thing ... it is right above that braided steel line and fitting on the lower side of the throttle body in the photo .. that is the throttle position sensor. When you examine it you will see how to unhook it...nothing to it ...it is a 2 minute job to replace it at the most
Old Feb 22, 2007 | 09:13 AM
loc's Avatar
loc
thanks very much I will try that today.
