What kind of lifters are needed for a solid roller setup?
Old Jul 31, 2002 | 03:31 AM
AlonzoVersion 1.0's Avatar
Default What kind of lifters are needed for a solid roller setup?
A buddy of mine wants to know and also who sales them and how much?
Old Jul 31, 2002 | 07:26 AM
RyanJ's Avatar
SSU Moderator
Default Re: What kind of lifters are needed for a solid roller setup?
uh....solid <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Crane makes solid lifters for the LS1. they're around $300 i think.
Old Jul 31, 2002 | 01:46 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan:
<strong>uh....solid <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Crane makes solid lifters for the LS1. they're around $300 i think.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Ryan do you know any sponsor that carrys them?I am trying to help my buddy out here <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ July 31, 2002, 01:47 PM: Message edited by: Alonzo ]</small>
Old Jul 31, 2002 | 03:28 PM
Jason99T/A's Avatar
I can shift faster than you.
Thunder has 3 sets in stock at this time.
Old Aug 1, 2002 | 07:39 PM
1dirtyZ's Avatar
what else would be needed for a solid cam set up ( other than the cam and lifters)???
Old Aug 1, 2002 | 07:56 PM
Will Race 4 Food's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong>what else would be needed for a solid cam set up ( other than the cam and lifters)???</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Adjustable rockers.. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jesel make the best IMO, but are$$$.
Old Aug 1, 2002 | 08:40 PM
<strong>what else would be needed for a solid cam set up ( other than the cam and lifters)???</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Also valve cover spacers and longer plug wires.
Old Aug 2, 2002 | 01:23 AM
1dirtyZ's Avatar
i got the crane adj. rockers, so do i need the valve cover spacer and wires??
if properly adjusted, what are the benifits of a solid valvetran when compared to a hydraulic setup?
Old Aug 2, 2002 | 06:56 AM
GeorgeC's Avatar
<strong>if properly adjusted, what are the benifits of a solid valvetran when compared to a hydraulic setup?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In a nutshell, you can run a much more aggressive camshaft, since you aren't so limited by spring pressure as in a hydraulic setup (too much spring pressure in a hydraulic setup will collapse the lifters). Usually the lobes on a solid roller cam are almost square-like in their shape. They open and close the valves very fast. A side perk is that idle quality and part throttle driveability are usually improved with the more aggressive solid roller cam, because of the fact that the valves are actually spending less time off the seat. The downside is the higher cost of components, and the additional maintenance required.
Old Aug 4, 2002 | 05:28 AM
1dirtyZ's Avatar
how about noise??
will it be louder??
so if i have the rockers ,p-rods,lifters, and cam
i'll be set??
what if i use them with my current cam??
Old Aug 5, 2002 | 03:16 AM
<strong>how about noise??
will it be louder??
i'll be set??
what if i use them with my current cam??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It will be louder and you need rocker arms,cam,lifters,valve cover spacers,and longer plug wires.I am going with the T&D rocker arms.Also you have to have your heads machined for the shaft mounted rocker arms.
