Quick question on Warranty Voids!!!!!!!
Is this true???
James
I've heard some companies voiding warranty's cause in the fine print it said something about having stock wheels and tires.
Dude has different wheels, no more warranty.
That's with most of the aftermarket companies though.
But I could bet GM won't like the fact that you have Drag Radials on it, as it proves racing and abuse, which is against the contract.
Swap em out!
Also, your public post of this very topic will likely play into you losing your warranty.
GM reads these messages boards.
i'd be more worried about them removing the motor thats in the car now and losing your 243 heads!
they will use the heads - if anything it will be a short block replacement. The may even change the crank, it all depends on the condition of the block.
thanks
BIll
Drag radials come into play when your wheel well is covered in rubber and they can claim you were beating the hell out of your car and deny your warranty claim.
You people sound like your letting dealers walk all over you. They cannot just void your warranty because you pull in with DR's. It is a street tire and totally legal to run on your vehicle.
I would see drag radials hurting you if you popped the tranny, rear end, clutch, etc.... but not the motor. Clean the car well.
Z
