5.3 vs 5.7 vs 6.0 L heads??
Is anyone running the 5.3 or 6.0 heads in a head/cam package?? I know the 5.7 L heads would be best, but i've heard about guys running 5.3 or 6.0 L heads for a heads/cam package. My questions are... which heads are the cheapest unported?? Which heads work best on our cars after port/polishing. Does anything have to be done to the 5.3 or 6.0 heads to make them work best (valves?) Also, my goal is about 420 rwhp, but still maintain great drivability, what size should i have the heads i choose ported?? and what brand of cam and specs would would work well with my heads. Also i have a 99 so should i go with larger injectors? I also plan on going with a LS6 intake when i do this over the winter. I want to save as much money on this project as i can, so if anyone knows where i can get a set of stock heads i know a guy that will cnc port them for a few hundred. I also plan on doing this myself. Is this a good idea if i have never done this on an ls1 before? Also for you guys that have done it yourself, would you do it again or just pay to have it done? sorry this is so long, thanks for your time!!!!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
LS1 Tech Administrator
5.7 and 5.3L heads have similar ports and will flow the same when ported. The 5.3L heads will give nearly a 1 point increase in compression which is good for close to 20 rwhp on an LS1 motor with a good cam. Advantage 5.3L heads.
The 6.0L heads ('01 and up aluminum versions) outflow all 5.7L and 5.3L heads by a good margin because they're based on the excellent LS6 heads. When ported, they flow about 10 numbers better than 5.7L heads or 5.3L heads, but it comes at a price. The combustion chamber is a little bigger than the 5.7L heads and a lot bigger than the 5.3L heads.This means compression ratio will drop and across the board torque will decrease. If you mill the 6.0L heads enough to make the chamber smaller and gain some compression back, they are the best head of the ones you mentioned. And affordable.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
New, the heads are priced similarly. Used, it varies based on demand. 5.3L heads used to be dirt cheap, but since the word's out that they're the hot ticket for high compression, the price has risen. 6.0L heads are hard to find used...too new.
__________________
420 rwhp with no custom tuning with 5.3 heads here. Compression on the 6.0 will be less but they can be milled to get a good comprssion out of them.
Thanks guys, It sounds like each head has its pros and cons. I may just go which whichever heads i can find at the best price. What size should i get them ported to? Should I just go with a standard stage two size for my 420rwhp goal? Also what cams seem to work well? I've heard and read alot about the TR224 cam, would this be a good choice? Also for you guys that did the install yourselves, was it extremely difficult? Thanks again!!!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Anyone else have any info on the 5.3L heads?? I can use any help I can get. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
You might want to try doing a search for 5.3 heads.A whole world of useful info has been posted.I plan on looking in to some 5.3 too. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
