Jessel 2.1 ratio rockers
What do you think of these. Would this just be too much. I want atleast 1.8 on my new head set up but i want the best i can get also. Also i will be adding more cubes later on so i need to plan for that.
Stick with 1.7 and get whatever cam you want. Why change rocker ratios when you'll be changing the cam/heads/possibly shortblock anyways?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by sited12:
<strong>Well the rockers were going to be put on the new heads that i am building up.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So get some jesel 1.7 ratio rockers and just use those. There isn't a point to changing the ratio when everybody is grinding quite nice cam's with super steep ramps that work well with our 1.7's. If you want more lift, just have the cam made with more lift.
go with jmX's advice. Stick with the 1.7's and get the cam ground to your specs. You can get more lift/lobe, etc. than you can "use" anyway with 1.7's.
Chris
Chris
I would just go with the 1.7's and get your cam ground to your specs.It will be plenty good for your setup. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
alright sounds good but does anyone have alot of wear and tear on their lifters from a big cam or are they taking it pretty well.
www.jesel.com they are 699 for the hydraulic rocker arms and 995 for the solid roller rocker arms.
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Alonzo:
<strong>www.jesel.com they are 699 for the hydraulic rocker arms and 995 for the solid roller rocker arms.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where are they on the site? I can not locate them.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ls1290:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Alonzo:
<strong>www.jesel.com they are 699 for the hydraulic rocker arms and 995 for the solid roller rocker arms.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where are they on the site? I can not locate them.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">They are hard to find but are there.Just email them and they will respond pretty fast.
