More 6.0L questions
Re: More 6.0L questions
5.7 / 346 = x / 409 (or 422) solve for x <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
~6.66Ls for the 409 and a 422 is ~7.0Ls
so is this nodular crank from australia the only other option as of now that we have for going to a stroker besides lunati? or does lunati make any cranks that may not be forged but aren't an insane price??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Bryan
Bryan
More 6.0L questions
I read in GMHTP magazine that you can get a 6.0 block for $700. With a 4.060 bore and a 4.0" stroke you can get 409 cubes. Prostockjon said something about a 4.075 offset and I have no idea what that is but it gives you almost 422 cubes. I'm wondering what is needed to build this motor. Obviously you would need a crank and new pistons. I would not use my stock cam but if I wanted to could I use my stock cam and heads? What else could you not salvage from your current LS1? I'm just wondering how cheaply I could step up to some serious cubic inches in case I suddenly need to get my motor rebuilt. I would rather step up than repair the puny 346. Any help would be appreciated. Thanks guys.
Justin
Justin
I can shift faster than you.
All parts from your stock LS1 are interchangeable. You would actually get 408.something (round up to 409...)cubic inches with a 4.030" bore and a 4" stroke crank.
That is the setup I have.
Shane
Shane
See the article in Vette mag last june or july. ..they built a iron blocked LS1 to 421CI. they said all heads, pullys, etc bolted right on...
...the real issue here is weight, however. the IRON block is 100lbs more!!
Where did you see the 6.0 L bare block for $700. I was told at my local dealer it was 2700. Told her I wanted the bare block and she said that was the price. I would prefer to pay 700 and step up to 6.0 L iron myself.
Thanks
Wes
Thanks
Wes
Here is one on ebay with forged pistons (for a 375ci motor/stock crank) for $200. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1854939424
hey john, dont you mean 364ci for stock displacement 6.0L?
offset grind the crank to 3.71 with a 4.03 bore and that would net you 378ci
I have rods and pistons for a 6L build up for sale. Setup for a 4.125" stroke and 4.030 bore. Lunati rods (pro billets) and ROSS pistons. Email if you want to work something out. I had them post in the for sale section.
Sean
BTW they are new
Sean
BTW they are new
LS1Tech Co-Founder
Stock 6.0 is a regular 4.000 bore.
Our stock LS1's are 3.900 bore but with a lot more stroke from the factory than previous SBC-typ GM engines.
NOW, I have a 422ci iron block.
bore x stroke = engine size
4.060 x 4.075 - 422ci
I'd just look for a used truck block not a new one. Stock 6.0 is a 377ci motor. You could bore it out .030 and offset grind the crank and make it even bigger.
