What damage can bent pushrods do?
Replacement pushrods are about $5 a piece (16 in a set). You should do the work yourself. Just remove the coil packs, valve covers and rocker arms. Pull the bent rods, replace them, re-install the rockers, covers and coils.
Good Luck
David
<strong>Just replaced mine. Do you heard a 'tapping' sound - in your engine? Loss of power? Good chance you got the 'bug'. I am totally machanical stupid. Most of the replacement is logical. Take your time. For complete details go to: www.ls1info.com
Good Luck
David</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Would a compression test show a bent pushrod?
do this. http://www.ls1info.com/article.php?sid=97
<strong>regarding the ls1info article on checking for bent push rods, the author says to "turn car over with starter" before final tightening of the rocker arms. how do i do this?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With the coil packs and valve covers not installed, place the key in the ignition and turn it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
In LS engines, all 16 push rods are generally the same. Swapping 2 of them around generally has no effect.
So, first question to be answered is, what are you working on?
