highest 5.3 head compression?
Old Sep 11, 2002 | 10:55 PM
sited12's Avatar
Default highest 5.3 head compression?
Wouldnt the highest compression you can run safely on pump gas be what they are at. The 5.3 heads bump compression up a point and stock is 10 so wouldnt these be 11:1. I figure possibly i could get them milled 30 still though but i am not sure. Let me know if getting them milled would still be a safe move for 93 octane or will this create detonation a WOT. Also still needs to beable to get in street races <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 12, 2002 | 04:18 PM
sited12's Avatar
Default Re: highest 5.3 head compression?
ttt
Old Sep 12, 2002 | 06:01 PM
VINCE's Avatar
Shorty Director
There is more than meets the eye.. Cam choice is important as well.. If you go to high on the compression you will need a huge cam to bleed off some compression to be able to run on pump gas..
Old Sep 12, 2002 | 10:07 PM
sited12's Avatar
So the higher the compression the higher the cam. Sounds good cause i was looking into getting a big lumpy stick.
Old Sep 12, 2002 | 10:34 PM
VINCE's Avatar
Shorty Director
I am surprised others have not chimed in.. There is a lot more than what I told you, but it kind of sums it up. I am going bigger cam..
Old Sep 12, 2002 | 11:02 PM
sited12's Avatar
12 has a nice ring to it but i am not sure how out of control the cam would have to be to run that compression.
Old Sep 12, 2002 | 11:15 PM
VINCE's Avatar
Shorty Director
Huge cam.. Take my advice.. It is not worth the trouble. You will not see that much of a difference from 11.3:1 to 12.1:1 unless you are running race gas... I would stick with what everyone else is doing.. Look how big of a cam Fireball is running to bleed off 11.8:1...
Old Sep 13, 2002 | 12:23 AM
sited12's Avatar
Yeah i wasnt sure how big it would take. So it looks like i will just get the 5.3 heads milled 30 maybe only 15. Not sure. Any more comments on this set up.
Old Sep 13, 2002 | 06:29 AM
Fireball's Avatar
I'm sure I could get away with a smaller cam...
with 11.8:1, I'm still leary on 93 octane laying into it in 4th gear.
<small>[ September 13, 2002, 06:29 AM: Message edited by: Fireball ]</small>
Old Sep 13, 2002 | 10:23 AM
99 Black Bird T/A's Avatar
.02
Also weight, gear and cooling will have an impact.
With the bigger SLP radiator, the JPR EWP using reverse flow cooling, low temp stat, lower fan settings and 4.10's, might be able to get away with a little more compression with the same cam, than without.
