Quiet Cam
Old Mar 12, 2007 | 06:56 PM
blackbird95's Avatar
Default Quiet Cam
I'm looking to buy a cam but I was wondering what would be the best one to put in my car and have it be a sleeper. I love the way a nice lumpy cam sounds but for my daily driver I want it to be a little bit incognito. My goal is around 360-400 rwhp. Any help would be appreciated.
Old Mar 12, 2007 | 06:58 PM
NviouSS's Avatar
look into the stealthI/II, cheaTR and gt2-3. i ran the gt2-3 for a couple years and put down around 365 rwhp.
Old Mar 12, 2007 | 07:07 PM
ZetaVeinteOcho's Avatar
A smaller cam like 220/220 - 224/224 range on a 114 lsa should get you there and keep it somewhat tamed.
TSP's 224/224 XE and 224R off the shelf cams, alot of people have/had them and are a very good choice for what you want. But there are many out there, so do some homework, but you can't go wrong with the above. And it is strongly recommended you have the supporting stuff FIRST (like headers, CAI, catback..etc), before the cam install. good luck
Old Mar 12, 2007 | 07:48 PM
Yeah I'm going to make sure the motor can breathe before I put the cam in, I was just getting some idea of what size cam to put in just in case I run across a good deal.
Old Mar 12, 2007 | 07:51 PM
Lythropus's Avatar
there was someone on here who made some great numbers with a stealth 2 and stage 2 heads. it was around 430+ if I remember correctly...
Old Mar 12, 2007 | 08:40 PM
Studytime's Avatar
Maybe Patrick G. will chime in. He made impressive power with the Thunder Racing CheaTR camshaft. I'm sure if you search under his name, you'll find the thread.
I've had the chance to hear two CheaTR cam'd cars, and both were very quiet.
Ben T.
Old Mar 13, 2007 | 01:45 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Get something that will have a less than -5 degrees of overlap and it will sound closer to stock. My 224/230 .581/.588 114+2 cam is -1 degrees and it doesnt have any lope to it hardly going through a chambered muffler with a dump.
Old Mar 13, 2007 | 01:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just arrange the posts from most replies in the Internal section, and his says " Torque coming out of my ears!!!!!"
Old Mar 13, 2007 | 08:22 AM
Ragtop 99's Avatar
You also need to decide where you want your power before selecting your cam - low end, mid-range, top end, spin to 7k?
