Rod bolt install write-up
i got rod bolts 100 years ago for my turbo set up, but ended up buying rods.
i still have the bolts so im going to swap them into my current stock short block build im doing.
cheep insurance with free parts. lol
good info. the motor i have has the sleve. doh
I was just confused as to whether or not you measured the bolt stretch while the rod / piston was in the motor. Common sense would say yes... But sometimes motors are not common sense machines.
I do not plan on real high rpms.
Katech rod bolts were designed to be very similar in both weight and length to stock rod bolts, while considerably more durable for high rpm use. Pricey, but I felt the extra coin was worth Katech's assurance regarding rod honing (not necessary).
Granted, if an individual was tearing the shortblock apart anyway, rehoning the rods and purchasing the less expensive ARP's might be a wiser use of money.
. While underthere and playing with the K member and major components around the engine, other then doing new motor mounts (or bushings if you are doing a kmember swap) is there anything else thats labor intensive that can be done while everthing is apart under the car?
