Rod bolt install write-up
Old Mar 20, 2007 | 06:22 PM
  #41
Katech_Jason's Avatar
LS1TECH Sponsor
Nice write-up.
Thank you!
Old Mar 21, 2007 | 09:30 AM
  #42
brad8266's Avatar
Thanks for making this a sticky Patrick G.
Old Mar 22, 2007 | 02:06 PM
  #43
Krab's Avatar
Originally Posted by gun5l1ng3r
You will have to spin that sucker to 6000RPM and let us know how it holds together.
I am too nervous to put Rod Bolts in because my Z28 is my Daily Driver and if I spin a bearing for any reason I am SOL!!
I've already spun it to 6600 rpms ~8 times since the install of the rod bolts and everything is ok. Now, the 10-bolt is suffering.
Thanks for making this a sticky, I barely noticed it today.
Old Mar 23, 2007 | 06:53 AM
  #44
ss1129's Avatar
Would it be worth it to change the rod bearings on a high mileage car while your down there?
Old Mar 24, 2007 | 03:56 PM
  #45
redtail2426's Avatar
i did it the same way,one bolt at a time,and three passes on each bolt with a final at 50.After this i put on 4k miles over last summer and had 7 dyno pulls to 6600..My rev limiter ws set at 6600 the whole time and i hit the limiter at least 10 times on the street.Major tack lag in first with 420 rwhp.i used the katecks also.
Old Apr 6, 2007 | 10:24 AM
  #46
Dom's Avatar
Dom
I have a 2000, do I need to change them before doing a cam? What's the limit of the stockers?
Old Apr 6, 2007 | 10:26 AM
  #47
brad8266's Avatar
Dont need to for a cam swap. I would spin the stockers up near 7k though.
Old Apr 13, 2007 | 11:53 AM
  #48
Halloran's Avatar
Ditto...Also what about the cam bearings?
Old Apr 13, 2007 | 11:55 AM
  #49
brad8266's Avatar
Dont cahnge the cam bearings unless they are damaged, to replace them the block has to come out of the car. major PITA juts to replace for the hell of it.
Old Apr 19, 2007 | 05:10 PM
  #50
patriotformula's Avatar
so before i put the new (out of a wrecked car) motor in my car should I change rod bolts? Its a 2000 motor and I plan to spin it to 7. Im just afraid of messing something up doing this, ruining the integrity of the motor. Thanks in advance fellas.
Old Apr 19, 2007 | 05:58 PM
  #51
Krab's Avatar
If you have the motor on a stand, it makes the install so easy. You plan to rev to 7k, so I'd say do it.
Old Apr 23, 2007 | 10:58 AM
  #52
So you guys have put some miles on after doing the rodbolt install with no problems? I just wanna make sure Im taking the right precautions
Old Apr 23, 2007 | 11:49 AM
  #53
Project Dc2's Avatar
A+ on the write up, how long did it take you to do the swap ?
Old May 4, 2007 | 09:51 AM
  #54
1baddls1's Avatar
is it possible with out removing the K
heard its possible buutttttttttttt
Old May 5, 2007 | 01:41 AM
  #55
Krab's Avatar
Project Dc2: The swap took me a total of ~16 hours from the time I jacked the car up to the time I fired her up. Keep in mind this is the first time I've attempted this. With a write-up, I'm pretty sure the time it would take someone to do it would be significantly less.
1baddls1: It is possible to do the swap without lowering the K-member, but you'd have to pull the engine. Since I don't have the tools to pull the engine, I chose the lesser of the two evils.
Old Jun 12, 2007 | 08:07 PM
  #56
Pipelayaz's Avatar
He said 16 hours.
Old Jun 17, 2007 | 10:58 PM
  #57
will69camaro's Avatar
Sex On Wheels
Wow damn i have to do this soon. Not looking forward to 16hrs of work. Did you do it by yourself or did you have alot of help? I'm doing heads/cam/intake and rod bolts to be safe...I guess wish me luck lol.
William
Old Jun 18, 2007 | 02:23 AM
  #58
Krab's Avatar
Just did another rod bolt swap last weekend and it took considerably less time than the first time I had done it. I started it at ~2pm and finished ~12am with a break here and there. So, it took ~10 hours from start to finish this second time around. All work done by myself. As you can see from the pics, it is a lot of work so be prepared for a lengthy install. Eat plenty of banannas for the potassium content, you'll probably get a cramp or two on your hamstrings during the install.
Have to give credit to brad8266, it's much easier unbolting the compressor and tieing it up somewhere.
Old Jun 18, 2007 | 06:17 AM
  #59
eallanboggs's Avatar
Krab: If you had the tools to pull the engine would you go that route or would you still remove the K member? Which is more work; the K member or the engine?
Old Jun 18, 2007 | 06:52 AM
  #60
calongo_SS's Avatar
Any problem holding the engine up under the bellhousing? I'm gonna be doing a k-member swap and dropping the oil pan. I'm kind of worried about holding the engine up from there. It doesn't seem like it would be too stable. Did the engine/trans ever feel unstable?
