Who knows about Mr. Moly!
I have been researching molybdenum disulfide (MoS2) for a while now. The research I have read is very compelling...up to the point where I am going to try using this product in my 1999 SS.
Of particular interest are the engine oil modifier (http://www.mrmoly.com/engine-aide.html) and the gear and/or transmission oil/fluid modifier (http://www.mrmoly.com/gear-aide.html or http://www.mrmoly.com/trans-aide.html), depending on if you have an Auburn or Torsen differential. This might be the answer (or at least help) with all of the gear whining problems that plague the LS1 community, especially us with 4.10's.
Anyone else have any comments? I find this product to be pretty fascinating.
-Kris
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
If you just add moly to a different oil that doesn't have it, you could upset the balance of the oil and it will oxidize faster and it's Total Base Number will drop too fast as the oil will work itself too hard.
If for some reason you do decide to add this additive, run half as much as they recommend. I looked into this stuff before and it's very highly concentrated moly. You don't need as much as they give you. In smaller doses it will still have the desired protection, without upsetting the oil's balance as much.
<strong>Thanks for the reply Patman. BTW, I am a chemist! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Kris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Then go for it! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Seriously though, if you are going to use this product, oil analysis is the best way to determine if it's use is safe or not, and determine the correct dosage too. I will say that this additive is going to be a lot safer than those snake oils out there, that is for sure. Let us know the results!
-Kris
Supposedly Mobile 1 uses about 90-100ppm MoS2 (as of the recent formula change), a couple other oils, like Valvoline, use 20-40ppm MoS2. Redline, from what I have heard, uses 500-600ppm MoS2.
I looked into MolySlip too (on the web) and was unable to find anyway to order it online or otherwise. Their site suggested that CarQuest distributed it nation-wide in the USA but I was unable to find it on the shelves at a local store. They told me they had never heard of the product and knew nothing about it. So I searched the web somemore until I found Mr. Moly. That company had an online ordering system and I could find absolutely no difference in their composition (as described).
-Kris
<small>[ September 22, 2002, 07:43 PM: Message edited by: 99WhiteSS ]</small>
I'm not quite sure why Redline uses so much moly though. Only a portion of that moly they use is going to bond, the rest will just remain in the oil. So they might be spending needless amounts of money on their oil (since moly is expensive)
