Are all cams created equal??? TR vs. MTI
Old Oct 11, 2002 | 07:48 AM
Billiumss's Avatar
Default Are all cams created equal??? TR vs. MTI
I will be buying stage 1 heads from a friend of mine very soon. He has informed me that the heads have been milled down .050 and the compression is now 11:1.
In that case, I have to run shorter push rods: 7.350
As for cams, if you have the same specs but made by different manufacters, are they the same, or more importantly, will they perform the same??? Specs are specs right???
I was going to buy a TR224 114lsa cam and use it with my stock heads. Then my friend said he would give me a good deal on his heads. So that changed everything....
After doing some research and talking to Jason at Thunder Racing, I probably shouldn't use the TR 224 cam due to the longer duration and might have valve to piston contact. I could cut my pistons, but thats not going to happen. Jason suggested that I could do the clay test and then measure the clay to see how much clearance I will have.
I asked if just using a slightly smaller cam will help and he said yep!!!
So the cams I am looking at are:
Thunder Racing TR220 220 .553 114 lsa (Jason said website is wrong, it really is .553 lift)
MTI B1 221 221 .558 lsa 114
My friend is using the MTI T1 cam (112 lsa) with his heads and doesn't have a problem with it working with the milled heads. He offered the cam to me at a great deal, but I want a smoother idle, plus I am going to spray 75-100 shot of Nitrous.
So which one should I get? Are that basiclly the same?
Please educate me....
Bill
Old Oct 11, 2002 | 10:54 AM
steve's Avatar
Default Re: Are all cams created equal??? TR vs. MTI
i would even consider the 216/220 comp split duration. ive seen good results from that one with a near stock idle...
steve frank
Old Oct 11, 2002 | 11:35 AM
horist's Avatar
hmmm... I would think that the TR cam would be fine... unless they use more aggressive lobe profiles...
DriveATransAm has the comp cams 224 grind which has .002 more lift than the TR and he has milled heads (.050) and is running awesome times
Old Oct 11, 2002 | 02:49 PM
AlonzoVersion 1.0's Avatar
Raughammer is running the 224/224 dur 581/581 112+4 with his heads milled .60 thous and has no piston to valve issues.
Old Oct 11, 2002 | 03:23 PM
Billiumss's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Alonzo:
<strong>Raughammer is running the 224/224 dur 581/581 112+4 with his heads milled .60 thous and has no piston to valve issues.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very interesting. What brand cam is this?
Who is this person, I need to talk to him...
Also, what does the "+4" mean???
Old Oct 11, 2002 | 03:26 PM
Reckless's Avatar
Super Moderator
BIll....Raughammer is John Campbell and hangs mostly in the drag racing forum. He has one of the fastest NA cars around. I believe this is a Thunder cam.
Todd
Old Oct 11, 2002 | 03:36 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Reckless:
<strong>BIll....Raughammer is John Campbell and hangs mostly in the drag racing forum. He has one of the fastest NA cars around. I believe this is a Thunder cam.
Todd</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No it is a comp cam and you can get it from any vendor.I would get it from speed inc because its cheaper 379-429 you take your pick and the +4 means 4 degrees advance were ground into the cam.
Old Oct 11, 2002 | 03:40 PM
Raughammer's Avatar
D(irecto)r Pepper
LOL. OUCH, it is NOT a thunder cam(though there is nothing wrong with thunder cams), it IS a MTI/comp cam cam.
Call em up and ask about it... or look on my web page....there is a LOT of info on the cams your interested in, including the C2 (224/224 .581/.581 )
The +4 would mean there is 4 degrees of advance ground into the cam. (thats a good thing)
Good luck on your cam search!
<small>[ October 11, 2002, 03:44 PM: Message edited by: Raughammer ]</small>
Old Oct 12, 2002 | 12:43 AM
JS's Avatar
JS
I agree with Stve,The 216-218 is a great cam along with the 218-224.FWIW,I went 11.40@117 with S1/218 cam and it idled very well
JS
