6.0 or LS1/LS6 Motor???
Old Oct 20, 2002 | 01:48 PM
Slammed Vette's Avatar
Default 6.0 or LS1/LS6 Motor???
Does everything bolt back up to the 6.0 block?What would I have to do to it to add a stroker crank and rods(what size pistons)?Would it be more noticable then a 382 on a LS1/LS6 motor?Extra power worth the extra weight?????Also what hp icrease would I see by going to a 6.0 over a 382 stroker?What would I have to do to make it a 408???Was thinking about a 408 on an iron block if I can't find a LS1/LS6 block.
<small>[ October 20, 2002, 02:28 PM: Message edited by: Slammed Vette ]</small>
Old Oct 20, 2002 | 03:46 PM
RyebreadZ28's Avatar
Default Re: 6.0 or LS1/LS6 Motor???
A 382 is 6.3L I believe, so it would have a slightly higher potential for more power.
A 408 is done by (someone correct me if I'm wrong) having a 6.0L block bored over .030" (4.030" bore) and by having a 4" stroke.
Old Oct 20, 2002 | 04:40 PM
So if I buy the 382 storker kit with diffent pistons and get a 6.0 iron block and have it bored I can get 408??????What size pistons would I need to get????And how mush bore????Also does the rest of the LS1 parts bolt back on the 6.0 block???
Old Oct 20, 2002 | 05:11 PM
MattG's Avatar
I believe everything bolts up to the 6.0L block.
If you are going to buy a stroker crankshaft, you may as well go with the 4.125" stroke and get 422ci out of it with a 4.030" bore. The more cubes the better to make up for the extra weight, unless you plan on reving it past 7000rpm.
Old Oct 21, 2002 | 12:40 AM
Spellbound's Avatar
Would any machine work need to be done, to put a larger than 4' inch stroker crank in a 6L iron block?
Old Oct 21, 2002 | 01:42 AM
Quickin's Avatar
So how many liters is my motor?
Old Oct 21, 2002 | 08:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Quickin:
<strong>So how many liters is my motor?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">7.18L or 7.2L rounded up <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 21, 2002 | 02:58 PM
FASST's Avatar
I don't believe you can bore the iron block .125" over. I'm pretty certain 4.060" bore is the max (or 60 over). 30 over is all I'd do if you plan on using power adders (forced induction or nitrous). The 409 is acutally a 4.030 bore and a 4.00" crank (408.17 actually).
Just wanted to clear things up.
Old Oct 21, 2002 | 04:07 PM
Ok one more ??? What do I do for head gaskets on a 6.0L motor bored 30/1000th.Do I use stock 6.0L gaskets or 5.7? Or is ther somwhere to get custum made ones?
Old Oct 21, 2002 | 04:22 PM
Just ordered the 408 stroker kit and Chris hooked me up with some gaskets too!!!!Iron block is on it's way too!!!!
Old Oct 22, 2002 | 11:02 AM
Axle's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Slammed Vette:
<strong>Does everything bolt back up to the 6.0 block?What would I have to do to it to add a stroker crank and rods(what size pistons)?Would it be more noticable then a 382 on a LS1/LS6 motor?Extra power worth the extra weight?????Also what hp icrease would I see by going to a 6.0 over a 382 stroker?What would I have to do to make it a 408???Was thinking about a 408 on an iron block if I can't find a LS1/LS6 block.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Slammed Vette~ why would you do something like that? what is a stroker? i think that is nuts <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Axle
Old Oct 22, 2002 | 01:16 PM
Brownie's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FASST:
<strong>I don't believe you can bore the iron block .125" over. I'm pretty certain 4.060" bore is the max (or 60 over). 30 over is all I'd do if you plan on using power adders (forced induction or nitrous). The 409 is acutally a 4.030 bore and a 4.00" crank (408.17 actually).
Just wanted to clear things up.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You are correct on the max bore size, but Matt was refering to increasing the stroke from 4" to 4.125" to gain additional cubes.
4.03" Bore x 4" Stroke = 408
4.03" Bore X 4.125" Stroke = 421
Mike
<small>[ October 22, 2002, 05:16 PM: Message edited by: Brownie ]</small>
Old Oct 22, 2002 | 01:53 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run a 4.060 bore 422ci iron block and I run Cometic head gaskets.
