Heads/Cam package - Your thoughts
- Magic Stick V.4 239/242, .649"/.609" Camshaft w/lobe seperation of 111.
- AFR 205cc Mongoose heads with a 66cc chamber.
- And of course all the supporting mods and what not.
- Possably deck the head as well to increase compression? Not sure about this one.
Should sound pretty bad *** with my headers/X-Pipe ad other bolt ons.
-From what I been hearing I'm going to have to flycut the pistons as well. Whats the pros and cons of flycutting your pistons?
I have also been looking at the a "less agressive" Magic Stick V.3 237/242 .603/.609" w/lobe seperation at 112.
Would this be considered a good street/strip setup?
After you flycut the pistons perform a PTVC test too see how much room you have to work with to mill the heads and mill them as far as you can to get to PTVC of .080 intake/.100 exhaust.
Do not dare mill the heads unitl you check your PTVC!!
going by your sig, I see you picked up a few more ponies
what did you do to your setup?
Sorry about the hi jack.
